What colour laser?
What colour laser?
Postby salan3 » Thu Jun 13, 2013 9:38 am
All,
I have finally removed Windows form all but one pc at home (wife still will not move over lol).
We have a Dell 1320cn printer that works well with my (mainly Unbuntu) machines.
But there are some good deals on 'All in one' colour lasers, but which will work with 64 bit Linux?
It still seems an area that we are let down in Linux world.
Which is a shame. I have everything else working fine (Games utils the lot, some using WINE but they work fine).
Printing always becomes a problem however.
So advice please?
I don't do a lot of printing( so no costly solutions), but I DO need to do some.
I would like to get a colour laser that is an 'all in one' so that we can use tit as a copier also, but from Linux, I just need to print.
I have scanners (there is another mine filed! lol).
Alan
salan3
Postby nelz » Thu Jun 13, 2013 9:58 am
Check the database at linuxprinting.org but it is hard to go wrong with HP as they provide open source drivers for their printers, scanners and AIOs.
Postby salan3 » Thu Jun 13, 2013 10:45 am
Thanks for that. I have looked there and it is so sad that there is not more choice especially with the selection of 'all in ones' etc out there now. Some at very cheap prices. Hp are great, but the cost is more then I can justify for the amount of printing I do.
salan3
Postby nelz » Thu Jun 13, 2013 12:33 pm
There is more choice, but HP is the safest bet. With anything else, check it on linuxprintng.org before buying.
I bought a Brother AIO laser last year. It's a nice piece of kit, reasonably priced and good quality. Driver installation was less straightforward then with HP, because Brother don't appear to get how Linux and FOSS are supposed to be used.
Postby roseway » Thu Jun 13, 2013 12:50 pm
I have a Canon MF8030Cn which works well with my Debian Testing 64-bit system. I have to say though, that it's not fast. The first print takes quite a long time to appear.
Eric
roseway
Postby johnhudson » Thu Jun 13, 2013 8:55 pm
If you only do a little colour printing, taking a PDF to your local printshop will be cheaper than buying a laser printer.
Get an all-in-one inkjet for the other functions and the times you don't need colour.
Postby salan3 » Wed Jun 19, 2013 7:17 am
johnhudson wrote:If you only do a little colour printing, taking a PDF to your local printshop will be cheaper than buying a laser printer.
We used to have that but the inks just kept drying up!
That's why we have a colour laser. It can sit there for months and work when we switch it back on.
Yes it would be cheaper to just take a file to local to be printed ,but not useful enough as I do not have access to a car, so you a\re talking about two bus journeys etc. and about two hours to get something printed.
salan3
Postby johnhudson » Wed Jun 19, 2013 8:59 pm
OK, have you the room for a simple colour laser printer and an all in one inkjet? That would probably be cheaper.
Brother works for me
Postby tweetiepooh » Fri Jun 21, 2013 12:35 pm
We have a Brother hl4040cn and it works (mostly) under Linux.
CUPS recommends the foomatic driver but that leads to E1 error on the printer so stick with the Brother driver. This can be got from the Brother site and is simply a matter of installing 2 packages :
1 for lpr
1 for CUPS
We chose the Brother because of Linux support and because for £200 we got a network printer supplied with full cartridges (1500 pages) and 3 years on-site support.
Trouble is now its a few years old and the generic carts seem less good than anticipated spares would cost more than a new printer. So we are also looking to replace it. Would choose Brother again but are not set on it.
tweetiepooh
