SOLVED echo newline to output file
Postby purplepenguin » Tue Jun 04, 2013 10:17 am
Hello
I've been working on a little script that searches my media server for .nfo files, extracts the title and plot information from said .nfo files and write the data to a txt file.
This is what I've got so far
IFS=$'\n'
cd /home/$USER/Network/server/Videos/$1
for file in $( find . -iname '*.nfo' );
do cat $file | grep -e '<title>' -e '<plot>' >> ~/movielist.txt
done
I'am trying to make the output easier to read by putting a newline or line of ================= between the plot and the next title.
Sample output:
 <title>Corpse Bride</title>
    <plot>Set in a 19th-century european village, this stop-motion animation feature follows the story of Victor, a young man whisked away to the underworld and wed to a mysterious corpse bride, while his real bride Victoria waits bereft in the land of the living.</plot>
    <title>WALL·E</title>
    <plot>WALL-E is the last robot left on an Earth that has been
What I would like is :
I have been trying to add an echo line to the script, but I'm not sure if echo is the right command to use or even where to put it.
Could anyone suggest how I could amend the script?
Thanks
PP
purplepenguin
Postby nelz » Tue Jun 04, 2013 11:05 am
echo is indeed the command to use, place it on the line before "done"
echo >> ~/movielist.txt
or
echo "=====================" >> ~/movielist.txt
Postby purplepenguin » Tue Jun 04, 2013 11:18 am
Thanks Nelz
I've tried:
IFS=$'\n'
done
It has the desired effect. But the output goes to the terminal. The txt file is created but empty, It's as if the
goes to stdout and the
echo
follows >> ~/movielist.txt
Hmm
purplepenguin
Postby nelz » Tue Jun 04, 2013 1:01 pm
Because you're no longr redirecting the output of grep. With your code, the file shouldn't be empty, it should contain a newline for every file processed. Incidentally, the use of cat with grep is usually unnecessary and undesirable
for file in $( find . -iname '*.nfo' ); do
grep -e '<title>' -e '<plot>' $file >> ~/movielist.txt
echo >>~/movielist.txt
done
Postby purplepenguin » Tue Jun 04, 2013 8:31 pm
cheers Nelz
I was confusing ">>" with ">".
I forgot that ">>" means append to file. I was trying to incorporate the "echo into the main part of the script before the first ">> ~/movielist.txt"
Of course, the ">> ~/movielist.txt" can be used more than once as it appends to the file not over writes it. Doh.
I get it now.
Process the the first .nfo file, write data to file and append the echo. Then process the second .nfo append data to end of file. etc etc.
Thanks for your help.
purplepenguin
