File indexer suggestion
Postby mm2ps » Wed May 15, 2013 7:18 am
I am looking for a program that will provide a list of my files and I can add comments to. An index list (maybe data base) of my files that I can add things like authors, description etc.
When the indexer is run it would try to match the previous comments with the correct file, even if it has moved.
I would not mind having to guarantee a degree of unique file naming.
Please, do you have any application suggestions?
All the best,
Douglas
mm2ps
