XBMC for Debian Wheezy
Postby Dutch_Master » Mon Apr 22, 2013 1:24 am
So far, the latest XBMC is not available as a package outside Ubuntu. I've created a script that installs XBMC from source on a minimal Wheezy system.
Prerequisites:
  • At least a minimal Wheezy system, newer may or may not work
  • Working internet connection
  • Add the contrib and non-free sections for the standard Debian repo's, as well as the multi-media repo from Marrilat: http://www.deb-multimedia.org/
When that's done, fetch the script here Next, rename the script from .txt to .sh then make it executable with chmod +x Prior to running the script, check and tweak it to suit your system. Once satisfied all's well, run the script.
What it does:
First, it prepares your system to install and build XBMC by installing the required dependencies. Next, it fetches the latest version from the Git repo, then compiles a required library as the supplied version is too old. Then it configures the xbmc source and starts compiling, the actual build process. Lastly, it gives you a clue on how to start xbmc.
I've tested the script in a virtual machine and it works. The script isn't fail-safe, you may brick your machine! (OK, maybe not that bad, but it can do serious damage to your data!) Use at your own risk!
Thoughts, suggestions and success reports welcome :mrgreen:
PS: it does not install any graphical interface, it's your desicion to use Gnome3, KDE4, XFCE or any other desktop manager...
Return to Hints and tips
