Auto disconnect network after 20 minutes of inactivity
Postby serene » Tue Mar 26, 2013 12:50 pm
Hi.
I wish to have my network disconnect after 20 minutes of inactivity.
I'm using the network-manager-gnome.
1. To determine if there are any network connections;
$ iptstate -1 -t | grep -c "Total States: 0"
0 = There are connections
1 = There are no connections
2. To disable the network;
$ nmcli nm enable false
It's been a while, my bash scripting is rusty.
Could someone please recommend a simple bash script I could run a cron job every 15-20 minutes that would check if there had been zero network activity so I can disable the network ?
Thank you.
Serene
serene
Postby nelz » Tue Mar 26, 2013 2:39 pm
iptstate -1 -t | grep -q "Total States: 0" && nmcli nm enable false
Provided iptstate shows details for all connections since the last run and not just the current time.
Postby serene » Wed Mar 27, 2013 12:07 pm
Thanks Nelz.
I didn't explain well enough.
Every 10 minutes, check for network activity...
if none, note.
Revisit 10 minutes later, if there is 'still' no network activity,
disconnect.
Thank you.
Serene
serene
Postby nelz » Wed Mar 27, 2013 4:20 pm
Something like this?
if iptstate -1 -t | grep -qv "Total States: 0"; then
  rm -f /tmp/no-network-activity
  exit
  fi
if [[ -f /tmp/no-network-activity ]]; then
else
  touch /tmp/no-network-activity
  fi
Postby serene » Wed Mar 27, 2013 5:49 pm
Thank you so much Nelz.
Mine didn't look anything like that.
Beau-ti-fulllllllll. Much appreciated.
Odd how there isn't a feature in gnome or network-manager
to acomplish this.
Best regards,
Serene.
[SOLVED]
serene
Postby nelz » Wed Mar 27, 2013 6:10 pm
serene wrote:Odd how there isn't a feature in gnome or network-manager to acomplish this.
Maybe because no one has asked for it? I can't think of a need for it myself.
