linux mint battery problem
Postby 1slipperyfish » Fri Mar 22, 2013 8:57 pm
hi guys, i have now gone all in with linux mint on my laptop (i lost my recovery partition) i didn't notice when i was using windows as well but the battery never seems to charge up?? it says "battery discharging" but never gets any more charge than zero
anyone got any ideas of a remedy as my leg is on fire cos its well hot when it's plugged in Embarassed
thanks in advance Very Happy
paul
edit:
i deleted this post because it suddenly showed that the battery was 100% charged,now it's back to zero and i haven't unplugged it???
1slipperyfish
Forum Jester
Postby lok1950 » Sat Mar 23, 2013 1:05 am
How old is the battery Paul it's quite likely that it's past due for replacement.I fear that it is the same issue you posted about before.
Enjoy the Choice :)
lok1950
Postby 1slipperyfish » Sat Mar 23, 2013 10:16 am
yo it's about three weeks old and it works ok this morning i've been going an hour after i just unplugged it and the battery still says 70%, apparently it's a linux mint(ubuntu) i have looked online and loads of people have the same problem but no one has a solution i thought one of you linux experts might have some killer skills and have a script change or summat??
ta
paul
edit:
then it just died again about ten seconds later it normally lasts 2 + hours in windows and i was only surfing???
1slipperyfish
Forum Jester
Postby nelz » Sat Mar 23, 2013 12:23 pm
If it's distro-specific, change distros - at least until a fix is found.
Postby 1slipperyfish » Sat Mar 23, 2013 12:34 pm
what would you recommend?
1slipperyfish
Forum Jester
Postby 1slipperyfish » Sat Mar 23, 2013 3:38 pm
thanks for your recommendations :roll: i recommend this http://www.youtube.com/watch?v=cFZtoWmlrq0 i went to see them before christmas and it was the best pop concert i have ever been to 8) may contain swearing
paul
1slipperyfish
Forum Jester
