chriswadams
Posted: Sat Mar 09, 2013 1:51 am Post subject: [SOLVED] Ubuntu w/ Openbox -- shutdown doesn't work properly |
I've recently installed Ubuntu's 12.04 mini.iso with Openbox and Simple Login Manager, on an Acer Aspire One netbook. I want to be able to shutdown and restart from the Openbox menu, but I can't get it to work. There are a number of threads with solutions to similar problems over on the Ubuntu Forums, but none of them has worked for me. Note that I can shutdown with the terminal command '$sudo shutdown -h now'.
Here is the XML I have in my 'menu.rc' file:
| Code: | <item label="Restart">
<action name="Execute">
<prompt>Are you sure you want to Restart?</prompt>
<command>sudo shutdown -r now</command>
</action>
</item> <item label="Shutdown">
<prompt>Are you sure you want to Shutdown?</prompt>
<execute>sudo shutdown -h now</execute>
</action> |
In place of the command 'sudo shutdown -h now', I have used 'sudo /sbin/shutdown -h now', 'sudo /sbin/halt', 'gksu shutdown -h now', 'x-terminal-emulator -t sudo shutdown -h now', and even 'x-terminal-emulator -t shutdown -h now'. Nothing works.
My visudo file looks like this:
| Code: | # User privilege specification
root ALL=(ALL:ALL) ALL
%shutdown ALL=(root)NOPASSWD: /sbin/reboot
%shutdown ALL=(root)NOPASSWD: /sbin/halt
%shutdown ALL=(root)NOPASSWD: /sbin/shutdown
%admin ALL=(ALL)ALL
%admin ALL=NOPASSWD: /sbin/reboot, /sbin/halt, /sbin/shutdown
# Members of the admin group may gain root privileges
%admin ALL=(ALL) ALL
# Allow members of group sudo to execute any command
%sudo ALL=(ALL:ALL) ALL |
Any help would be appreciated.
Thanks,
Chris Adams.
nelz Moderator
Posted: Sat Mar 09, 2013 9:47 am Post subject: |
It would hel p if you were more specific than "not works". Do you get any error messages? Are there any entries in the system log?
I susepct that sudo wants a password but doesn't have a terminal to ask for it. You could try gksudo instead, or use visudo to edit /etc/sudoers to allow /sbin/shutdown to be run without a password.
Then add
| Code: | | yourusername ALL = NOPASSWD: /sbin/shutdown |
_________________ Unix is user-friendly. It's just very selective about who it's friends are. |
chriswadams
Posted: Sat Mar 09, 2013 1:27 pm Post subject: [SOLVED] Ubuntu w/ Openbox -- shutdown doesn't work properly |
Nelz --
I apologize for my vagueness; by "not works", I meant that the shutdown command simply wouldn't do anything. It wouldn't give any response at all.
But your suggestion worked perfectly. Thanks so much for your help!
Chris Adams |
