If and Grep
If and Grep
Postby thusgaard » Wed Mar 06, 2013 4:42 am
Hi
I'm trying to create a list of pictures that contain GPS information.
I have all the picture that I need to examin in one directory and I have a bit of script that works, but not as good as I would like.
#!/bin/bash
# My first script
for file in 'ls -1';
do if exiftool *.jpg | grep 'GPS L';
then
   exiftool *.jpg | grep 'File Name\|GPS L' > test.txt
else
   echo "Negativ"
fi
done
This code scans all the *.jpg files in a dir for GPS information stored in EXIF. Then it saves the filename and the GPS information to a file called test.
My problem how ever is that it saves all the filenames, also the ones not containing EXIF GPS information.
File Name                       : noEXIFtest.jpg
File Name                       : noEXIFtest2.jpg
File Name                       : EXIFtest2.jpg
GPS Latitude Ref                : North
GPS Longitude Ref               : East
GPS Latitude                    : 34 deg 56' 17.78" N
GPS Longitude                   : 135 deg 38' 41.91" E
File Name                       : EXIFtest.jpg
What Am I doing wrong?
J;-)
thusgaard
Postby nelz » Wed Mar 06, 2013 9:48 am
Can you post the full output from exiftool on one of the file that does not contain GPS info but does appear in the list.
Postby MartyBartfast » Wed Mar 06, 2013 9:50 am
These line are exiftool'ing ALL jpgs so it will always find at least one match:
then
you probably want to do
do if exiftool $file | grep 'GPS L';
then
   exiftool $file | grep 'File Name\|GPS L' > test.txt
you could probably achieve the same result with
exiftool *.jpg | egrep "File Name|GPS L" | egrep -B1 "GPS L" > test.txt
MartyBartfast
Postby thusgaard » Wed Mar 06, 2013 12:52 pm
This last bit works like a charm.
MartyBartfast wrote:you could probably achieve the same result with
And just for the interested I'll post a full EXIF log of a picture with no GPS info:
ExifTool Version Number         : 8.60
Directory                       : .
File Size                       : 176 kB
File Modification Date/Time     : 2013:01:26 21:55:42+01:00
File Permissions                : rw-rw-r--
File Type                       : JPEG
MIME Type                       : image/jpeg
JFIF Version                    : 1.01
Exif Byte Order                 : Big-endian (Motorola, MM)
Make                            : Canon
Camera Model Name               : Canon IXUS 1100 HS
X Resolution                    : 240
Y Resolution                    : 240
Resolution Unit                 : inches
Software                        : Paint.NET v3.5.10
Modify Date                     : 2012:03:02 08:32:06
Exposure Time                   : 1/500
F Number                        : 4.5
ISO                             : 200
Exif Version                    : 0230
Date/Time Original              : 2012:02:27 13:25:08
Create Date                     : 2012:02:27 13:25:08
Shutter Speed Value             : 1/500
Aperture Value                  : 4.5
Exposure Compensation           : 0
Max Aperture Value              : 4.5
Subject Distance                : 64.4 m
Metering Mode                   : Multi-segment
Flash                           : Off, Did not fire
Focal Length                    : 12.7 mm
Exif Image Width                : 3000
Exif Image Height               : 4000
Focal Plane X Resolution        : 16393.44262
Focal Plane Y Resolution        : 16393.44262
Focal Plane Resolution Unit     : inches
Sensing Method                  : One-chip color area
File Source                     : Digital Camera
Custom Rendered                 : Normal
Exposure Mode                   : Auto
White Balance                   : Auto
Digital Zoom Ratio              : 1
Scene Capture Type              : Standard
Sensitivity Type                : Standard Output Sensitivity and Recommended Exposure Index
Lens Info                       : 5-60mm f/?
Lens Model                      : 5.0-60.0 mm
Profile CMM Type                : Lino
Profile Version                 : 2.1.0
Profile Class                   : Display Device Profile
Color Space Data                : RGB
Profile Connection Space        : XYZ
Profile Date Time               : 1998:02:09 06:49:00
Profile File Signature          : acsp
Primary Platform                : Microsoft Corporation
CMM Flags                       : Not Embedded, Independent
Device Manufacturer             : IEC
Device Model                    : sRGB
Device Attributes               : Reflective, Glossy, Positive, Color
Rendering Intent                : Media-Relative Colorimetric
Connection Space Illuminant     : 0.9642 1 0.82491
Profile Creator                 : HP
Profile ID                      : 0
Profile Copyright               : Copyright (c) 1998 Hewlett-Packard Company
Profile Description             : sRGB IEC61966-2.1
Media White Point               : 0.95045 1 1.08905
Media Black Point               : 0 0 0
Red Matrix Column               : 0.43607 0.22249 0.01392
Green Matrix Column             : 0.38515 0.71687 0.09708
Blue Matrix Column              : 0.14307 0.06061 0.7141
Device Mfg Desc                 : IEC http://www.iec.ch
Device Model Desc               : IEC 61966-2.1 Default RGB colour space - sRGB
Viewing Cond Desc               : Reference Viewing Condition in IEC61966-2.1
Viewing Cond Illuminant         : 19.6445 20.3718 16.8089
Viewing Cond Surround           : 3.92889 4.07439 3.36179
Viewing Cond Illuminant Type    : D50
Luminance                       : 76.03647 80 87.12462
Measurement Observer            : CIE 1931
Measurement Backing             : 0 0 0
Measurement Geometry            : Unknown (0)
Measurement Flare               : 0.999%
Measurement Illuminant          : D65
Technology                      : Cathode Ray Tube Display
Red Tone Reproduction Curve     : (Binary data 2060 bytes, use -b option to extract)
Green Tone Reproduction Curve   : (Binary data 2060 bytes, use -b option to extract)
Blue Tone Reproduction Curve    : (Binary data 2060 bytes, use -b option to extract)
Image Width                     : 600
Image Height                    : 800
Encoding Process                : Baseline DCT, Huffman coding
Bits Per Sample                 : 8
Color Components                : 3
Y Cb Cr Sub Sampling            : YCbCr4:2:0 (2 2)
Aperture                        : 4.5
Image Size                      : 600x800
Scale Factor To 35 mm Equivalent: 5.6
Shutter Speed                   : 1/500
Circle Of Confusion             : 0.005 mm
Depth Of Field                  : inf (6.07 m - inf)
Field Of View                   : 28.4 deg
Focal Length                    : 12.7 mm (35 mm equivalent: 71.1 mm)
Hyperfocal Distance             : 6.70 m
Light Value                     : 12.3
thusgaard
