Unable to open file with .dtp extension
Postby joshua » Thu Feb 28, 2013 2:50 pm
Hi, In 2009 I created a file which I then saved. I now can't open it. I have no idea what program I used to write it. Also I can't remember whether I used XP, Vista or Mint to write it I have tried scribus and libre office to open it but no luck. As I have said the file has a .dtp extension and is quite large so probably has images in it and was maybe written with some form of desktop publisher. Any ideas please..
joshua
Postby nelz » Thu Feb 28, 2013 3:39 pm
Try using the file command to identify it
file somefile.dtp
Postby joshua » Thu Feb 28, 2013 3:55 pm
I have found the file I just can't open it...
joshua
Postby lok1950 » Thu Feb 28, 2013 4:04 pm
Just did a goggle of .dtp lots of useful stuff :wink:
File created with Publish It one of the links was from the scribus forums on importing .dtp files
Enjoy the Choice :)
lok1950
Postby ajgreeny » Thu Feb 28, 2013 4:07 pm
It looks as if scribus, which is probably available in all distro's repositories can open .dtp files.
Worth a try, I think.
ajgreeny
Postby nelz » Thu Feb 28, 2013 4:20 pm
joshua wrote:I have found the file I just can't open it...
file identifies the file, you're thinking of locate.
Quite a few Windows programs use the .dtp extension, you need something a bit cleverer to see what it actually is, like file.
Postby joshua » Thu Feb 28, 2013 4:47 pm
Nelz, sorry about that, done what you suggested and got the following
barry@desktop ~ $ ls
AlaskaPhoto.iso Desktop Downloads Modelling Pictures SingaporeDiary Videos
Album Diary kdenlive Music Projects test Writings
bookmarks-2012-09-05.json Documents Misc one recipes Travel ZipDiaries
barry@desktop ~ $ cd SingaporeDiary
barry@desktop ~/SingaporeDiary $ ls
diary.dtp
barry@desktop ~/SingaporeDiary $ file diary.dtp
diary.dtp: Composite Document File V2 Document, Little Endian, Os 0, Version: 5.1, Title: greenstreet publisher 3 document, Subject: Samples, Author: GST technology LTDComposite Document File V2 Document, corrupt: Can't expand summary_info
barry@desktop ~/SingaporeDiary $ ^C
I think it says it was composed with greenstreet publisher and is probably corrupt.
joshua
Postby johnhudson » Thu Feb 28, 2013 10:00 pm
KDE File Associations doesn't know anything about it - which suggests it is a pretty rare type.
I have sometimes been able to access unknown files with Kate; unless it is completely encoded in binary, the text can normally be copied and pasted into another file.
Another possibility would be to use:
strings -a --encoding={b,l} -n 2 diary.dtp
You may need to tweak the options but that is a good starting point.
Postby joshua » Fri Mar 01, 2013 11:56 am
Thanks for the efforts, I have now tried everything I can think of from Kate to Open Office I made this file on an old laptop which came with Green Street publisher on it. I still have the laptop but not the programme on it and I can't find the additional disc that came with the machine. I have found that there are copies of Green Street publisher out there but of a later version which apparently doesn't read older version files. Fortunately I still have the written copy and the photo's so it looks like a lot of writing to do..
joshua
