Help installing kompozer
Postby heiowge » Tue Feb 12, 2013 11:04 am
I've downloaded it. Unzipped it. ./configure doesn't work. Nor does sudo apt-get install kompozer Nor does running kompozer shell script. :?
I'm mystified. Every guide seems to tell me a different method to get it. One said it was in the repositories. It wasn't.
Anyone help?
Postby Dutch_Master » Tue Feb 12, 2013 11:14 am
I'm not surprised:
KompoZer 0.7 is not compatible with GTK ≥ 2.14 — expect crashes. If you’re using a Linux distro that ships KompoZer 0.7.10 with GTK ≥ 2.14, please inform the package maintainers about this.
(see http://www.kompozer.net/download.php)
Mint 14 is definitely using GTK> 2.14, so it fails. Get the latest source (0.8 branch) then follow these instructions: http://kompozer.sourceforge.net/dev/
Postby heiowge » Tue Feb 12, 2013 12:31 pm
Thanks. I got as far as this bit...
copy the “mozconfig” file for your platform, from the mozilla/composer/config directory to mozilla/.mozconfig
e.g. for MacOS X:
cp mozilla/composer/config/mozconfig.mac mozilla/.mozconfig
And couldn't find the mozconfig file.
btw, it was the .08 build I was trying.
