Resolution stuck on 1024x768
Postby heiowge » Sat Feb 09, 2013 7:25 pm
Help! My resolution won't switch back to 1440x900 (default). When I try and switch it back, my monitor just displays a notice that it has no signal!
This doesn't appear to do anything:
Any ideas. Oh, and the windows partition is displaying the correct resolution. :roll:
Postby heiowge » Sat Feb 09, 2013 7:38 pm
Oh, and the image size here is down to photobucket. Damn thing keeps resizing them to 1024 x 768... :x
Postby heiowge » Sat Feb 09, 2013 7:55 pm
Booting into KDE solves it. The driver is even set to the nVidia proprietary one. :?
Looks like it's just MATE. Although it was working fine this morning...
Postby heiowge » Thu Feb 21, 2013 11:53 pm
Resurrecting this topic. Now KDE is having the issue. Even a reinstall (including the /home partition) will only give me 1360 x 768 instead of 1440 x 900 (as it used to be). Everything looks stretched. I don't like it. :shock:
Postby heiowge » Fri Feb 22, 2013 4:50 pm
...aaaaaaaaaaaaaaaaaannd it's sorted again! :roll:
Turns out that the VGA splitter didn't support 1440x900 (even though it says it's fine with higher resolutions and below). I realised it wasn't a driver issue when I had the same issues with Windows.
Users browsing this forum: Google [Bot], towy71 and 2 guests
