Suitable OS for EEEPC 701
JohnA1954
PostPosted: Thu Feb 07, 2013 12:42 pm    Post subject: Suitable OS for EEEPC 701 Reply with quote
Hi Everyone.
I know that there are loads of replacements for the original OS on the 701 and have tried several (Mint, Ubuntu, Lubuntu) but they all suffer from one problem: When connecting to a Wireless network they have the option to show the encryption key in text. We have 30 of these netbooks in the school I work in and we cannot allow this key to be made available to the pupils. The original OS does not show the key but is obviously well out of date.
Can anyone suggest a suitable OS that would not show this.
Many thanks in advance.
John
PostPosted: Thu Feb 07, 2013 2:10 pm    Post subject: Reply with quote
Have you tried plain Debian? (install a minimal text system, then load XFCE or similar, but steer clear from KDE and Gnome!)
PostPosted: Thu Feb 07, 2013 6:56 pm    Post subject: Reply with quote
Is the 701 the 4G version? I have the 2G version. The biggest issue with a distro is size. Most distros these days are slightly larger than 4GB. Have you tried Ubuntu 10.04. I know it's not 100% up to date, but it is supported still.
Maybe puppy linux?
Failing all that, have you thought of Ubuntu Server an then installing XFCE over the top (along with any other essential apps)?
Or you could always install to an SD card...
AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
eeepc 1015PX, 1.66 Ghz Intel atom processor, 2 GB DDR3, 320 GB hd running Mint 14 MATE. Running great.
PostPosted: Thu Feb 07, 2013 8:19 pm    Post subject: Reply with quote
Guys, while your replies are trying to help they don't address the issue of hiding the wep/wpa password problem; I'm sure someone knows the right answer it just ain't me Wink
PostPosted: Thu Feb 07, 2013 11:30 pm    Post subject: Reply with quote
I thought most distros had a handle on it. It's just that the eeepc's default Xandros is crap! Laughing
PostPosted: Fri Feb 08, 2013 8:30 am    Post subject: Reply with quote
Isn't that just while you do you the initial entry of the password, once it's set you have made the first connection it then can't be seen.
Edit.
Having checked, you can still recall it.
Edit #2
You could de-install Network Manager and install WICD as the last post in this thread states
JohnA1954
PostPosted: Fri Feb 08, 2013 5:29 pm    Post subject: Reply with quote
Thanks for the replies.
Apologies for not responding earlier but our Internet was down all day at work.
Yes the password can still be seen after a reboot. The original Xandros does not but as mentioned it is crap.
I am currently trying Dutch Master's suggestion of Debian. I use Squeeze as my main os but originally had thought it would be too large. Got as far as the basic install last night and still to install XFCE. (over the weekend)
RAM, thanks for that suggestion and sounds like an option to try if Squeeze does not work out.
Thanks again for your help, will post over weekend results.
John
Oh well!
PostPosted: Sat Feb 09, 2013 12:19 am    Post subject: openSUSE Reply with quote
Here's an idea if you don't solve the problem with Debian:
Install openSUSE --> open YaST (requires entering the administrator password) --> Select Network Settings --> A message will appear saying that the 'network is currently controlled by Network Manager [Gnome desktop]: use that or switch network setup to traditional with ifup' --> click OK --> deselect 'User Controlled with Network Manager' and select 'Traditional Method with ifup' --> and then you're on your own--I'm still using Network Manager because it's simple and works. However, switching to ifup would, presumably, ensure that the network password is hidden from ordinary users and require that the administrator password is needed to view it. openSUSE makes switching to ifup easy; it will be possible in other distros, but it's probably fiddlier to sort out.
