Installing Netflix on Linux Mint 13 - FIXED
Postby elenmar » Sun Feb 03, 2013 7:22 am
I have been attempting to install Netflix on Mint 13 using apt-get. This runs in a terminal window and goes well until it prompts for me to agree to a licence for a Microsoft component. This is simply a text button for 'Yes' - no alternative, no 'back' button.
The problem is that no matter what I do the text interface in the terminal window does not respond to either mouse or keyboard entries. If I then exit by closing the terminal window (the only way out that I can see) it leaves me with a mess that needs to be cleaned up manually and an aborted installation.
I seem to remember that there is a utility that can be installed to make text windows respond to mouse input but this is something from doing a Linux from scratch build a few years ago.
Any help, comments or suggestions would be welcome.
elenmar
Postby xenopeek » Sun Feb 03, 2013 8:24 am
Tab to highlight the option of your choice, Enter to accept that choice. If there is only one option, you still need to highlight it.
Linux Mint 14 Nadia / 64-bit / Cinnamon
xenopeek
Postby elenmar » Sun Feb 03, 2013 8:35 am
Thanks for that. It is now working fine.
elenmar
