Which Eclipse ?
Which Eclipse ?
Postby stuarte9 » Sat Jan 26, 2013 12:22 pm
I want to use Eclipse for software development and testing. Specifically UML, C/C++ and Java, as well as unit testing of the latter two. As I'm using OpenSUSE 12.2, I used YAST/Software/Software Management. This installed the following :-
ecj, ecj-bootstrap, eclipse-swt
However, nothing has shown up in the main-launcher/Applications/Development menus. I tried using (command not found) "cnf eclipse" in a terminal which resulted in "eclipse: command not found".
I then visited eclipse.org and found that there are many different versions, namely Europa, Ganymede, Galileo, Helios, Indigo and Juno.
As my PC is based on an Intel Pentium 4 running OpenSUSE 12.2, I understand that I need a Linux 32-bit version. However, other than that, this wide selection has left me confused.
Could some kind soul please point me in the direction of which version of eclipse I should install ?
Could you also please advise which plugins I need ? I know that I need cdt for C/C++ and jdt for Java. What plugins do I need for UML, and for unit testing of C/C++ & Java ? Will all these plugins be found on eclipse.org or will I need to source some of them from other locations ?
Thanks in advance for any help you may be able to give with this.
Stuart
stuarte9
Postby johnhudson » Sun Jan 27, 2013 8:35 pm
The openSUSE package is from the eclipse site and only gives you the basic Java compiler; you need to download the plugins for other languages.
Have you tried
ecj
in the konsole?
Postby stuarte9 » Tue Jan 29, 2013 3:37 pm
Hi John,
Thanks very much for the reply.
Typing ecj on its own into a console brought up a list of usage options. This I understand from previous experience to be normal "behaviour".
As you will see from my original posting, I'm trying to find out which "dialect"/generation of Eclipse is the correct and most up-to-date one for my Intel Pentium 4/OpenSUSE 12.2 system. I'm "talking" here about the full GUI based framework.
As I said in my previous posting, on the Eclipse website there are several "dialects" of Eclipse (the aforementioned Europa, Ganymede, Galileo, Helios, Indigo and Juno [please see previous posting]). This together with the fact that there are a number of packages for each "dialect" has left me somewhat confused as to which is the correct Linux 32-bit "dialect"/package and set of plugins for my PC.
I hope this helps clarify what it is that I'm trying to do (please see previous posting).
Best regards,
Stuart
stuarte9
Postby johnhudson » Tue Jan 29, 2013 9:30 pm
As this is an openSUSE specific question, why not visit the Programming forum at http://forums.opensuse.org?
Postby stuarte9 » Wed Jan 30, 2013 11:08 am
Good morning John,
That's a great Idea. I'll do that right away.
Thanks very much for the help. :-)
Best regards,
Stuart
stuarte9
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
