KDE and window panes
Postby GeordieJedi » Sat Jan 19, 2013 10:50 pm
Hi all.
Im using/experimenting with KDE at the moment.
I find it very hard (headache inducing) looking at the white panes (inside the windows).
For any length of time
I've had a look at the system settings and I can see a setting called "view background".
If alter this colour (to something like a light blue colour, then it's much easier on the eyes).
But anything the requires a white background (like the Kate or Gedit text editors
main text entry screens are then also turned light blue too)
So is there a way to change the background panes of windows without affecting everything else?
(Like how you could change the insides of windows to a pattern or a colour in the older versions of Gnome/Nautilus).
I've had a good Google round the net and experimented with some of the settings (in system settings) without much joy.
Info -
OS = Ubuntu 12.04 LTS
TIA for any help or advice.
GeordieJedi
Postby Ram » Sat Jan 19, 2013 11:43 pm
Are you using a TFT or CRT monitor ?
Postby GeordieJedi » Sat Jan 19, 2013 11:51 pm
@ Ram -
I'm using a TFT/LCD monitor.
GeordieJedi
Postby Ram » Sun Jan 20, 2013 4:45 pm
I used have issues with headaches and CRT monitors running at 60Hz, don't with FTF, with CRTs I needed at least 75Hz.
Postby nelz » Sun Jan 20, 2013 11:06 pm
You can change the text area background colour in Kate from its settings window.
