Missing file in kernel tree
Postby Dutch_Master » Sat Jan 19, 2013 2:43 pm
I've been trying to install the nVidia graphic driver installer in Debian Stable, with a freshly compiled 3.7.3 kernel. Unfortunately it complains about a missing file: /lib/modules/3.7.3/build/include/linux/version.h And indeed, it's not there in the tree. The 3.7.3 kernel is up and running, so it's not the issue. Can I copy the version.h file from a 2.6 kernel and what do I need to change for the nVidia installer to recognise the 3.7.3 kernel running.
TIA!
Postby guy » Sat Jan 19, 2013 4:42 pm
Try googling on Linux "version.h"
The version.h from an older kernel will not be good. I suspect that you'll need to create your own, to match your custom-complied kernel - I think that may mean a re-compile, I'm not sure: you'll probably understand more of the online discussions than I do.
Be careful with nvidia drivers. Debian defaults to the free Nouveau driver, but nvidia also offer their own blob. So you'll need to know which you are installing.
Don't know if that helps much.
"Klinger, do you know how many zoots were killed to make that one suit?" — BJ Hunnicutt
Postby roseway » Sat Jan 19, 2013 6:32 pm
It sounds as though you haven't got the kernel headers installed.
Eric
roseway
Postby Dutch_Master » Sun Jan 20, 2013 12:09 am
Thanks guys, much appreciated!
I know using an old version.h file for my new kernel isn't ideal, hence my question on what to change. I'm also aware about the Nouveau vs nVidia driver and I'll use the latter, blacklisting the free, non-3D versions. (I need the binary blob to run Google Earth, it won't work on the nv nor nouveau drivers...)
The kernel headers should be in place: I used a fresh kernel from the Linux.org guys and compiled it with the standard "configure && make && make install" sequence (OK, a little more involved to that, but it's not exactly the first kernel I've build ;)) Key is: it has worked on a 3.1.3 kernel before! (and I never had issues like this on the 2.6 kernels)
Postby nelz » Sun Jan 20, 2013 11:11 am
You don't use configuer && make && make install for a kernel, you use
make menuconfig
make all && make modules_instal && make install
Although I'm sure you know that.
Postby Dutch_Master » Sun Jan 20, 2013 12:44 pm
I do:
make xconfig
make && make modules && make modules_install && make install && mkinitramfs -o /boot/initrd.img-3.7.3 3.7.3 && update-grub
That's why I said "a little more involved" :P Took about an hour ;) (AMD quad-core, 32 GB RAM)
Postby nelz » Sun Jan 20, 2013 4:40 pm
I build the initramfs into the kernel, it avoids extra files, extra GRUB configuration lines and the possibility of a mismatch between the kernel and initramfs.
Postby Dutch_Master » Mon Jan 21, 2013 3:25 am
I'd prefer to keep the initrd image outside the kernel, it's more flexible that way (and takes about the same space, I'd reckon). Anyway, any thoughts on the missing version.h file (and the contents thereof, for a 3.7.3 kernel) or should I report this as a bug?
Postby nelz » Mon Jan 21, 2013 9:49 am
I want reliability, not flexibility. If the initramfs was optional, I wouldn't be using it in the first place.
As for the file, that file does not exist on any of my systems, so it appears to no longer be used. However, I don't use the nvidia drivers so I've never had cause ot worry about it. Could a later release of the nvidia drivers help?
Postby Ram » Mon Jan 21, 2013 12:08 pm
Got loads in mine, 3 newest are
/usr/src/linux-headers-2.6.32-45-generic/include/linux
and
/usr/include/linux
both with these 2 lines
#define LINUX_VERSION_CODE 132640
#define KERNEL_VERSION(a,b,c) (((a) << 16) + ((b) << 8) + (c))
The other one is in
/usr/include/linux/dvb
with this in it.
 * version.h
 * Copyright (C) 2000 Holger Waechtler <holger@convergence.de>
 *                    for convergence integrated media GmbH
 * This program is free software; you can redistribute it and/or
 * modify it under the terms of the GNU Lesser General Public License
 * as published by the Free Software Foundation; either version 2.1
 * of the License, or (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU Lesser General Public License
 * along with this program; if not, write to the Free Software
 * Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.
#ifndef _DVBVERSION_H_
#define _DVBVERSION_H_
#define DVB_API_VERSION 5
#define DVB_API_VERSION_MINOR 1
#endif /*_DVBVERSION_H_*/
Postby Dutch_Master » Mon Jan 21, 2013 12:45 pm
@Nelz, the nVidia drivers I tried are the latest releases (late 2012)
@Ram: I too have a 2.6.32 kernel, but its contents is obviously incorrect for a 3.7.3 kernel. The dvb file is irrelevant, as it's not a kernel but an application. Thanks anyway!
Postby Ram » Mon Jan 21, 2013 1:50 pm
Which driver are you using.
Similar issue but for Ubuntu here With 313.09 driver. 1 reply say use 313.18 driver.
Postby Dutch_Master » Mon Jan 21, 2013 2:48 pm
The 310 and 313 series aren't applicable for my GPU (GeForce 7 series) so it's the 304 and 173 series.
Postby cmcevoy » Sat Jan 26, 2013 4:11 pm
You need this snippet - obviously replace the kernel module with the version you have:
cd /lib/modules/3.7.1-17-desktop/build/include/
ln -s generated/uapi/linux
cmcevoy
Postby Dutch_Master » Sat Jan 26, 2013 5:36 pm
Many thanks, I'll give it a try later on :D
