Parallel Port Card Query
Postby TonyBradley » Mon Jan 07, 2013 9:58 pm
The parallel port on my motherboard is kaput, and I'm contemplating buying a PCI parallel port card to replace it.
Could I get advice on whether this will work, ie, allow me to run a printer from the add-on card? What sort of gotchas will I have to look out for?
TIA
TonyBradley
Postby ferrari » Thu Jan 10, 2013 8:27 am
This is legacy hardware, so sourcing could be an issue. One method of approach that might work for you
modinfo parport_pc
provides a list of vendor and product codes that are supported via this driver. From this info, you can search for the manufacturer with
http://www.pcidatabase.com/
Many of the cards associated with some of the chipsets are likely to be not in current production, but
For example, from
alias:          pci:v00001409d00007268sv00001409sd00009018bc*sc*i*
I located this card
http://www.sunix.com.tw/product/par5008d.html
Another:
http://lavalink.com/products/pci-bus-io ... -port-epp/
ferrari
Postby ferrari » Thu Jan 10, 2013 8:31 am
You may want to disable your damaged port in the BIOS as well (if possible). That way, only the good one will show up. Often, the parport_pc module must be loaded on boot, since parallel ports are not in common use any longer.
ferrari
