RaspBMC on Pi with Raspbian
Postby Sandersson » Sat Jan 05, 2013 11:08 am
Hi all
I have a Raspberry Pi finally up and running with Rasbian as OS.
I'm trying to follow the guide in Linux Format Issue 165 to get RaspBMC on to my Pi.
I have made a copy from the coverdisc of the file install.py to a usb and again made copy to my Pi desktop.
Then opend the LXTerminal and run the command
sudo python install.py
an got an error of the install.py not found.
I then copyed the fild to /home/pi and again run the command sudo python install.py
Someting is happening, but also nothins is happening.
My terminal looks like;
pi@raspberrypi - $ sudo python install.py
pi@raspberrypi - $
And nothing is happening. Looks like the command is accepted but not running?
Pease help anyone.
On beforehand thank you fore your help.
Sandersson
Ps. Please exscuse my english, it is ot my first spoken language.
Sandersson
Postby Sandersson » Sat Jan 05, 2013 2:00 pm
I just found this command;
curl -O http://svn.stmlabs.com/svn/raspbmc/test ... install.py
chmod +x install.py
And now it works.... :D
Found it here;
http://comoyo.github.com/blog/2012/07/2 ... pberry-pi/
Sandersson
Users browsing this forum: Bing [Bot], Exabot [Bot] and 3 guests
