Idiots' guide to file permissions for new files
cmcevoy
PostPosted: Mon Dec 10, 2012 11:28 pm    Post subject: Idiots' guide to file permissions for new files Reply with quote
I have several users. All belong to group 'users' and some to group 'adults'
There are two directories:
'Shared' is owned by :users, directory permissions 777, files 664
'Secure' is owned by :adults, directory permissions 770, files 660
All I want is for new files and subdirectories to follow this stucture. I've failed using GUID and failed using ACLs although I suspect that is the solution really.
Running 'find <...> | xargs chmod' every so often works, but surely there is a better way?
I'll provide the idiot if you provide the guide?
Thanks
PostPosted: Tue Dec 11, 2012 12:03 am    Post subject: Reply with quote
Default permissions for new files and directories follow the umask setting, but this is set per filesystem rather than per directory.
You really should be persevering with ACLs, this is exactly the type of situation they deal with. Rather than trying to re-invent the wheel, and probably ending up with a square one, it would be better to look at why ACLs don't do what you want.
Like most other software, setfacl does what you tell it to, not what you want it to, so post what you want, what you tried and what you actually got.
cmcevoy
PostPosted: Tue Dec 11, 2012 9:42 am    Post subject: Reply with quote
Thanks. I think I'd ended up with too many ACLs set, but since you confirmed I was on the right track I cleared them all then reset
Code:
setfacl -m d:g:users:rwx Shared
setfacl -m d:g:adults:rwx Secure
setfacl -m d:o:x Secure
and this seems to give what I want. Thanks for your encouragement.
