Out of range on boot
Postby leke » Tue Nov 13, 2012 3:45 pm
I recently got an old desktop pc from college and installed Ubuntu on it. At boot, I would get the message:
"Input signal out of range. Change settings to 60hz 1280x1024."
...but ignored it, because after about 5 seconds the OS would boot as expected.
After about a month though, it stopped booting normally and was stuck on the 'Input signal out of range' message.
With a live USB distro, I tried changing the /etc/default/grub GRUB_GFXMODE setting to match my monitor's resolution, but couldn't figure out how to mount the drive to run sudo grub-update so I gave up and installed xubuntu to see if made any difference.
I had the same problem with xubuntu though, but this time I decided to change the grub GFX setting before it could cause any more serious problems. It didn't change the message at boot though, and a few boots later, xubuntu now isn't booting just like ubuntu.
So, what do you think? Is it a hard drive problem or graphics driver or something?
Other stuff I've tried...
I tried attaching another monitor and that just outputs...
"Out of range."
leke
Postby Dutch_Master » Tue Nov 13, 2012 4:31 pm
Chip itself on its way out? If you add a video card, does it still happen?
Postby leke » Tue Nov 13, 2012 7:50 pm
Dutch_Master wrote:Chip itself on its way out? If you add a video card, does it still happen?
But the USB distro boots every time, so wouldn't that mean the video is ok?
leke
Postby leke » Fri Nov 16, 2012 12:12 pm
I tried another hard drive with an old version of linux mint installed and got the same issue. Unfortunately, I don't have another graphics card to try out DM's theory.
leke
