LXF 165: Typos in Unison Tutorial
Postby maverickprowls » Sat Nov 10, 2012 12:01 pm
Hi there,
I've been running through James Litton's excellent Unison tutorial, and I've got everything working beautifully, synchronising a folder on 3 machines with a central server. I'd been trying to roll my own solution with rsync for a couple of weeks without much luck, so the tutorial was perfectly timed.
I noticed two things in the shell script provided in the article. One I know is a typo, the other was my mistake, but is down to the poor differentiation between 1 and l in the font used for code in the article.
Line 11 of the script
if [${stst:0:7}] == "Nothing"]; then
should be
if [${stat:0:7}] == "Nothing"]; then
However, when I initially copied out the script, I noticed that I was getting a notification even when the script had nothing to do. After a bit of poking around I realised that line 6 ends with
tail -1
but I had written
tail -l
with the letter L. After I made this correction, the script worked correctly.
Once again, many thanks for a really useful tutorial, and I hope the above helps anyone else who's having trouble getting this working.
maverickprowls
Postby guttagrynna » Thu Nov 15, 2012 8:58 pm
Thnks for this post. I ran the tutorial myself today, and got the sam two errors in my code. Correcting the second one makes no difference that I can detect, though. Which is odd and worrying.
I have used unison the manual way before, which has been working as expected. My problem now is that in batch mode it doesn't handle deletes right. If I delete a file on one computer it gets copied from the server on sync. I have version 2.32 (as opposed to 2.40) running - could it be an explanation?
guttagrynna
Users browsing this forum: Bing [Bot] and 4 guests
