Help & lead me to the end. VFS: readonly/fs couldn't mou
Postby xcislav » Fri Oct 12, 2012 4:21 pm
In a case of root=/dev/ram0 real_root=/dev/sda2
No filesystem could mount root, tried: ext3 ext2...
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(1,0)
http://imageplay.net/img/tya22288136/IMG0204A.jpg (real_root - real panic)
The case of omitting real_root and using just root=/dev/sda2
VFS: Mounted root (ext2 filesystem) readonly on device 8:2
http://imageplay.net/img/tya22288134/IMG0203A.jpg - after the last line hangs without panic (alt+sysrq+b helps)
List of all partitions (before kernel panic string):
0800 62522712 sda driver: sd
0801 204800 sda1 00000000-........0
0802 53928280 sda2 0...............0
0803 8388608 sda3 0........0
panic.....
Pid: 1, comm: swapper/0 Not tainted 3.4.9-gentoo #7
But, firstly about my system (wgetpaste -c lspci)
http://bpaste.net/show/50707/
# lspci
00:00.0 Host bridge: Advanced Micro Devices [AMD] nee ATI RX780/RX790 Chipset Host Bridge
00:02.0 PCI bridge: Advanced Micro Devices [AMD] nee ATI RD790 PCI to PCI bridge (external gfx0 port A)
00:05.0 PCI bridge: Advanced Micro Devices [AMD] nee ATI RD790 PCI to PCI bridge (PCI express gpp port B)
00:06.0 PCI bridge: Advanced Micro Devices [AMD] nee ATI RD790 PCI to PCI bridge (PCI express gpp port C)
00:0a.0 PCI bridge: Advanced Micro Devices [AMD] nee ATI RD790 PCI to PCI bridge (PCI express gpp port F)
00:11.0 SATA controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode]
00:12.0 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:12.1 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0 USB OHCI1 Controller
00:12.2 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:13.0 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:13.1 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0 USB OHCI1 Controller
00:13.2 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:14.0 SMBus: Advanced Micro Devices [AMD] nee ATI SBx00 SMBus Controller (rev 3c)
00:14.1 IDE interface: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 IDE Controller
00:14.2 Audio device: Advanced Micro Devices [AMD] nee ATI SBx00 Azalia (Intel HDA)
00:14.3 ISA bridge: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 LPC host controller
00:14.4 PCI bridge: Advanced Micro Devices [AMD] nee ATI SBx00 PCI to PCI Bridge
00:14.5 USB controller: Advanced Micro Devices [AMD] nee ATI SB7x0/SB8x0/SB9x0 USB OHCI2 Controller
00:18.0 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor HyperTransport Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Miscellaneous Control
00:18.4 Host bridge: Advanced Micro Devices [AMD] Family 10h Processor Link Control
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 03)
02:00.0 VGA compatible controller: NVIDIA Corporation GT218 [GeForce 8400 GS] (rev a2)
02:00.1 Audio device: NVIDIA Corporation High Definition Audio Controller (rev a1)
03:00.0 SATA controller: Marvell Technology Group Ltd. 88SE9120 SATA 6Gb/s Controller (rev 12)
04:00.0 USB controller: Fresco Logic FL1000G USB 3.0 Host Controller (rev 01)
05:06.0 Multimedia audio controller: Ensoniq ES1371 [AudioPCI-97] (rev 08)
http://bpaste.net/show/50727/
http://bpaste.net/show/50703/
http://bpaste.net/show/50705/
.config :
http://bpaste.net/show/50708/
grub.conf
http://bpaste.net/show/50709/
/etc/fstab (May it be wrong without /shm?)
http://bpaste.net/show/50710/
http://bpaste.net/show/50711/
http://bpaste.net/show/50721/
/etc/portage/make.conf
http://bpaste.net/show/50712/
dmesg (right after boot from installation usb)
http://bpaste.net/show/50726/
And in the hope of "Chapter 7", Linux Sea - my case could be some overlooked controller for my SSD Crucial M4 64. I need to clarify SSD is different with HDD in Kernel Setup? Or slightly.. mb AHCI+SATA+RAID is a must chain? As I have an AMD (asrock mb) I couldn't find where is my missed option PIIX (Intel PIIX or AMD analogy).
RAM and root file system support seem to be not very far from working system:
http://imgur.com/a/VSsHV
- genkernel failed in the same way (VFS). That's why i began my long path make && make_modules
I've done the kernel without initramfs [*] and 2 partitions in ext2 (/boot ,/ ) in order to lessen the possibility of fail (esp on SSD). I can't fild those two in kernel except for Marvell:
I have no HDD only SSD and bootable flash minimal x86_64. Is an "PIIX4 PATA/SATA support" approprietable to me?
Why bzImage is in arch/x86/boot/bzImage (x86_64 only links to x86). And what i'm doing - recompiling kernel again & again with replaceing with cp.
Based on Pappy Kernel Seeds. ((Thanks to all you.. to this forum, the art of not being rude to ppl. with creative environment))
xcislav
Postby nelz » Fri Oct 12, 2012 9:02 pm
SSDs appear to the system as SATA hard drives, so you just need AHCI and the usual block device support in your kernel. However, unknown block errors from kernel startup usually indicate that the drivers for your controller are not built into the kernel, either that or you have included the AHCI drivers but your BIOS is set to non-AHCI mode.
