Host Linux or host Windows
Postby pk_fox » Mon Oct 01, 2012 10:20 am
Hi all, I'm in the market for a new PC and need the capability to create virtual machines as I have to use Windows for my job. I have two questions. 1) Do I make Linux or Windows the host ? And 2) What sort of spec PC do I need to create VM's ( completely new to all things virtual )
pk_fox
Postby Dutch_Master » Mon Oct 01, 2012 1:05 pm
As you'd expect here, we recommend Linux as the host platform :P
As for the spec's: depending on other requirements, any PC with >2 GHz clock speed and 3 GB RAM will run a Win-OS guest. However, mind that Vi$ta requires a minimum of 2 GB RAM to work, so the more RAM you put in, the better it'll perform, for M$ standards of course ;)
FYI: my 'normal' supplier of PC components also has "upgrade kits". One has an Asus mainboard (FM1 socket), a top-end (-ish) AMD proc and 8 GB RAM (1333, IIRC) for under 200 Euro. Add enclosure, PSU (if not included in enclosure) and harddrive and basically, you'd be done for under 350 Euro.
Postby pk_fox » Mon Oct 01, 2012 1:10 pm
Dutch_Master wrote:As you'd expect here, we recommend Linux as the host platform :P
Sorry my bad, I meant laptop not desktop, thanks for the spec though at least I know now
pk_fox
Postby Ram » Mon Oct 01, 2012 5:46 pm
Same goes for Laptops.
Postby wyliecoyoteuk » Mon Oct 01, 2012 8:41 pm
Using Linux as the host has the advantage that you can run multiple instances of the same windows license (just not at the same time) for testing purposes, as the virtual and actual hardware remain the same.
I do this to maintain a software demo suite for incompatible applications.
Postby pk_fox » Tue Oct 02, 2012 6:28 am
wyliecoyoteuk wrote:Using Linux as the host has the advantage that you can run multiple instances of the same windows license (just not at the same time) for testing purposes, as the virtual and actual hardware remain the same.
Hi, thanks for your help, I can see I need to read some more on VM's - will Google for a tutorial.
pk_fox
Postby wyliecoyoteuk » Tue Oct 02, 2012 7:56 pm
Yeah, make a windows VM, activate and then clone it.
Because the hard disk, processor, gfx, and network card MAC address remain the same, it is effectively the same PC.
Just don't try to run more than one copy at a time.
Postby reklan » Wed Oct 03, 2012 8:30 am
OR look at dual boot...
If you need to use Windows for work purposes and Linux for personal use.. consider dual booting..
if the only reason was to use a VM for having the second OS.. with a dual boot setup. you can both OS's to their max ability and use your hardware to it fullest
Don't Dream it....Be it..
reklan
Postby wyliecoyoteuk » Wed Oct 03, 2012 12:28 pm
Only problem with dual boot is that you can only access one OS at a time.
Most modern PCs can easily support 2 or more OSes in VMs.
I have a 4 core AMD processor with 8Gb of memory, and it can happily run several VMs simultaneously.
My dual core 4 GB laptop can run 2 without a problem.
Postby reklan » Wed Oct 03, 2012 1:19 pm
Very true..
I must admit, I dual boot and use virtual machines.. I do however find that under Linux they do seem to run a tad faster than under windows..
but maybe its because i have moved to Virtual Box rather than Virtual PC/VM Workstation...
reklan
Postby pk_fox » Thu Oct 04, 2012 9:51 am
wyliecoyoteuk wrote:Only problem with dual boot is that you can only access one OS at a time.
Hi there, what laptop do you have ? I need to be able to run Visual Studio 2008 on the windows side of things and Fedora as my main OS. Thanks for your help.
pk_fox
Postby Ram » Thu Oct 04, 2012 10:23 am
I have an HP G62, 3 gig, I3 Quad core running Ubuntu 10.04 LTS and Virtualbox Ver 4.1.10r76795 running XP with 500 MB of Ram
This for testing / dev work.
MS SQL Server 2005
MS Visual C# 2008 & 2010 Express Editions
MS XNA Game Studio 3.0
If that helps
Postby wyliecoyoteuk » Thu Oct 04, 2012 10:53 am
Its a Lenovo core i5@2.3 GHz with 4Gb of memory
Postby pk_fox » Thu Oct 04, 2012 12:05 pm
Ram wrote:I have an HP G62, 3 gig, I3 Quad core running Ubuntu 10.04 LTS and Virtualbox Ver 4.1.10r76795 running XP with 500 MB of Ram
MS SQL Server 2005
If that helps
It does help thank you.
pk_fox
Postby pk_fox » Thu Oct 04, 2012 12:06 pm
wyliecoyoteuk wrote:Its a Lenovo core i5@2.3 GHz with 4Gb of memory
Thanks.
pk_fox
