heiowge LXF regular
Joined: Wed Feb 27, 2008 8:21 pm Posts: 1798 Location: Cheshire, UK
Posted: Sat Sep 29, 2012 2:21 pm Post subject: what the... |
Why is 1 core at full speed, but the rest are only at 800mhz? Is it that one only is being used, or that the rest have a fault? _________________ AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
eeepc 1015PX, 1.66 Ghz Intel atom processor, 2 GB DDR3, 320 GB hd running Mint 14 MATE. Running great. |
nelz Moderator
Posted: Sat Sep 29, 2012 6:08 pm Post subject: |
It's probably the kernel scheduler reducing the speed until it's needed. If your kernel uses the on-demand governor, this is to be expected. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
heiowge LXF regular
Posted: Sat Sep 29, 2012 6:17 pm Post subject: |
Thanks nelz. Any idea if Mint 13 includes this? _________________ AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
nelz Moderator
Posted: Sun Sep 30, 2012 11:11 am Post subject: |
| Code: | | zgrep CPU_FREQ /proc/config.gz |
should show you which cpufreq options are enabled in your kernel. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
heiowge LXF regular
Posted: Sun Sep 30, 2012 3:41 pm Post subject: |
| nelz wrote: | | Code: | | zgrep CPU_FREQ /proc/config.gz |
should show you which cpufreq options are enabled in your kernel. |
Typed that. Got this:
gzip: /proc/config.gz: No such file or directory  _________________ AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
Paradigm Shifter
Posted: Sun Sep 30, 2012 4:29 pm Post subject: |
It's called Cool 'n' Quiet, the AMD equivalent to Intel Speedstep.
It's BIOS controlled, and in my experience great if you want to decrease idle power draw, but a nightmare if you've got any software that is reliant on CPU clock to control its internal timing count - Unreal Tournament engine games spring to mind here; if you install them with the CPU 'idle' they'll run in fast-forward due to the CPU clocking up to full speed when the game actually runs.
Run linpack or something similar, and you'll see all cores at their rated 3200MHz.
It's interesting to see the evolution of power saving tech for CPUs - initially it was a bit of a sledgehammer solution (all cores clocked up or down) then it evolved to a load-based scenario (all cores have independent clock states depending on load) and the latest and greatest versions (semi-)intelligently work out how much a core can be overclocked based on load, TDP and temperature.
So, no, there's no fault there. It's doing what it's designed to. If you want it running full speed all the time, disable Cool 'n' Quiet in the BIOS.  |
nelz Moderator
Posted: Sun Sep 30, 2012 7:19 pm Post subject: |
| heiowge wrote: | gzip: /proc/config.gz: No such file or directory  |
Stupid distros trying to hide the kernel config. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
el chapulín
Posted: Mon Oct 01, 2012 2:06 pm Post subject: |
As it's a Debian based distro this should do it:
| Code: | | $ grep -i cpu_freq /boot/config-`uname -r` |
heiowge LXF regular
Posted: Mon Oct 01, 2012 3:55 pm Post subject: |
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_TABLE=y
CONFIG_CPU_FREQ_STAT=y
CONFIG_CPU_FREQ_STAT_DETAILS=y
CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y _________________ AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
el chapulín
Posted: Mon Oct 01, 2012 5:21 pm Post subject: |
Well the performance governor is configured as the default on that system... but you said that different cores are at different speeds, which as far as I know is not normal cpfreq behaviour - nor is it normal for speedstep or cool n quiet as far as I know.
The cores being locked to 800MHz could be a symptom of a lack of "dual power plane" support on the motherboard. You should verify this first and that your board is definitely an AM3 board and not an AM2+ or "AM3 optimised" board... your CPU, assuming it's the one in your signature certainly requires an AM3 board to realise it's full potential, but you haven't stated what motherboard you have. |
heiowge LXF regular
Posted: Mon Oct 01, 2012 8:13 pm Post subject: |
Its an ASRock M3A770DE. I hope that means more to you than it does to me. The manual says "Support for socket AM3 processors: AMD Phenom II X4 / X3 / X2 (except 920 / 940) and Athlon II X4 / X3 / X2 processors). _________________ AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
heiowge LXF regular
Posted: Mon Oct 01, 2012 8:25 pm Post subject: |
Maybe these will help?
el chapulín
Posted: Tue Oct 02, 2012 8:30 am Post subject: |
| Your board is ok. As a diagnostic test can you disable frequency scaling in the BIOS setup (if you're not sure how read the motherboard manual) and see if that causes all cores to return to their correct speed. |
Paradigm Shifter
Posted: Tue Oct 02, 2012 12:50 pm Post subject: |
Set 'Cool 'n' Quiet' to [Disabled]. Watch all CPU cores run at 3200Mhz.
Modern CPUs are designed in such a way as to allow cores to clock independently based on load.
This Anandtech review, particularly the second page, goes into a little more detail about 'Turbo' and power states on the CPU cores.
Was my previous post a figment of my imagination? You're looking for a problem when there isn't one. |
el chapulín
Posted: Tue Oct 02, 2012 1:49 pm Post subject: |
He has the performance governor enabled so all cores should at the highest clock, that is the issue.
I agree though, disabling cool and quiet should be the next step. |
