External drive not showing true capacity
Postby pk_fox » Fri Sep 21, 2012 9:57 am
Hi All, I've just dug out a Seagate external usb drive to backup some music data, however when I mounted it , df -h /dev/sdc only reports it as having 494mb, I'm pretty certain it's a 500gb but don't know how to find out - all help gratefully received
output
Filesystem Size Used Avail Use% Mounted on
devtmpfs 494M 0 494M 0% /dev
pk_fox
Postby ajgreeny » Fri Sep 21, 2012 10:32 am
You need to use that command for a partition, or partitions, to see the proper size, eg df -h /dev/sdc1
Use disk utility (palimpsest) if it's available for your distro and it may well show you a different size to df. It depends on whether the application uses 1000 or 1024 for the calculations.
ajgreeny
Postby pk_fox » Fri Sep 21, 2012 10:59 am
Thanks I'll take a look at it
pk_fox
Postby nelz » Fri Sep 21, 2012 11:39 am
df is for filesystems, not devices, all you are seeing is the size of the /dev/filesystem. To see the sizes of the disk and opartitions, use fdisk
sudo fdisk -l /dev/sdc
Users browsing this forum: Google [Bot] and 5 guests
