[SOLVED] (RTFM...)Channel listings for sky channels (Mythtv)
Postby bobthebob1234 » Fri Aug 24, 2012 11:13 pm
Got DVB-S (freesat card). It picks up channels from FreeSat and Freesat from sky
Selected radiotimes as source for channel data, and ticked use EIT as well.
I think it is only using EIT though cos channels that I pick up from freesat from sky don't show anything.
Sky only provides 'now and next' data, which mythtv only picks up when I manually watch that channel, not helpful when trying to record stuff...
So any ideas how I can debug / set up / tell myth to use radio times (or similar) for channels it can't get EIT data for?
Cheers
bobthebob1234
Postby bobthebob1234 » Sat Aug 25, 2012 3:21 pm
Move along, move along, nothing to see here...
Helps if you follow the hidden instructions...
http://www.mythtv.org/wiki/Uk_xmltv
bobthebob1234
