FranBlakes
Joined: Wed Dec 01, 2010 9:16 pm Posts: 82 Location: Worcs.
Posted: Wed Aug 22, 2012 5:19 pm Post subject: Raspberry Pi Kit |
Has anyone seen this offer:
http://www.maplin.co.uk/raspberrypi
Is it worth it, will anyone be taking up the offer? |
SpecialStuff
Posted: Wed Aug 22, 2012 5:59 pm Post subject: |
Hmm, I don't know much, but that looks overpriced to me. You probably have half of that gear lying around, and the stuff you don't have won't cost much. Just buy the Pi and get the other stuff you need separate.  |
nelz Moderator
Joined: Mon Apr 04, 2005 12:52 pm Posts: 7992 Location: Warrington, UK
Posted: Wed Aug 22, 2012 9:26 pm Post subject: |
If you've bought any sort of mobile device in the last 4-5 years, you'll already have a micro-USB cable and charger. Most computer enthusiasts also have old mice and keyboards lying around, probably the odd USB hub too. So all you're getting for your 70 quid is a 30 pound Pi and a wireless dongle.
Also note that they are only taking pre-orders, the exclusivity deal Pi have with Farnell and RS still has a while to run. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
bobthebob1234 LXF regular
Joined: Thu Jan 03, 2008 9:38 pm Posts: 1356 Location: A hole in a field
Posted: Wed Aug 22, 2012 10:19 pm Post subject: |
If you do have an old phone charger, make sure it is the correct voltages! Mine weren't!  _________________ For certain you have to be lost to find the places that can't be found. Elseways, everyone would know where it was |
nelz Moderator
Posted: Thu Aug 23, 2012 8:30 am Post subject: |
MicroUSB is 5V, that's the spec. There are some that don't deliver enough current, but they should all be 5V. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
Posted: Thu Aug 23, 2012 1:21 pm Post subject: |
voltages, current, its all the same to me  _________________ For certain you have to be lost to find the places that can't be found. Elseways, everyone would know where it was |
Ram LXF regular
Joined: Thu Apr 07, 2005 10:44 pm Posts: 1547 Location: Guisborough
Posted: Thu Aug 23, 2012 1:23 pm Post subject: |
| bobthebob1234 wrote: | voltages, current, its all the same to me  |
Just be careful with them amps  _________________
nelz Moderator
Posted: Thu Aug 23, 2012 1:31 pm Post subject: |
But not to your hardware  _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
Posted: Thu Aug 23, 2012 5:16 pm Post subject: |
Well so long as the little numbers and units match up, all is good  _________________ For certain you have to be lost to find the places that can't be found. Elseways, everyone would know where it was |
Bruno LXF regular
Joined: Tue Sep 18, 2007 7:07 pm Posts: 139 Location: Cambridgeshire, UK
Posted: Tue Aug 28, 2012 12:57 pm Post subject: |
It's the volts that jolt but the mill(iamp)s that kills  |
einonm
Joined: Fri Apr 20, 2012 11:19 am Posts: 29 Location: Cardiff, UK
Posted: Mon Sep 03, 2012 10:42 am Post subject: Re: Raspberry Pi Kit |
Certainly not! The ad has in it the magic phrase, several times, that tells you it's overpriced - "Gold-plated connectors".
Also, once it's up and running you usually don't need the extra mouse and keyboard, for example - http://bit.ly/JVKvOk _________________ "Debugging is twice as hard as writing the code in the first place. Therefore, if you write the code as cleverly as possible, you are, by definition, not smart enough to debug it." --Brian Kernighan |
heiowge LXF regular
Joined: Wed Feb 27, 2008 8:21 pm Posts: 1794 Location: Cheshire, UK
Posted: Mon Sep 03, 2012 11:00 am Post subject: |
If I were looking to buy a kit for the pi, for £70 I'd expect to see an HDMI cable, case for the Pi, 8GB SD card (minimum) and cheapy wired keyboard and mouse. _________________ AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
eeepc 1015PX, 1.66 Ghz Intel atom processor, 2 GB DDR3, 320 GB hd running Mint 14 MATE. Running great. |
heiowge LXF regular
Posted: Mon Sep 03, 2012 11:05 am Post subject: |
| Ram wrote: | | bobthebob1234 wrote: | voltages, current, its all the same to me  |
Just be careful with them amps  |
Running Scared - 1986 - car chase onto subway tracks
"Watch out for that third rail - it's 600 volts."
"It's not the volts that kill you, it's the amps."
"Well, how many amps are there?"
"Enough to push a train!" _________________ AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
peterr88
