Bluetooth AWOL on Acer Aspire One 725 w/Lubuntu 12.04 64-bit
Postby globetrotterdk » Sat Aug 04, 2012 3:40 pm
I have installed Lubuntu 12.04 64-bit on my Acer Aspire One 725, and finally have almost everything working as it should. One of the major exceptions seems to be Bluetooth. The specifications for the laptop state that the computer comes with Bluetooth 4.0, however Lubuntu seems unable to detect it:
$ lspci
00:00.0 Host bridge: Advanced Micro Devices [AMD] Family 14h Processor Root Complex
00:01.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Wrestler [Radeon HD 6290]
00:01.1 Audio device: Advanced Micro Devices [AMD] nee ATI Wrestler HDMI Audio [Radeon HD 6250/6310]
00:04.0 PCI bridge: Advanced Micro Devices [AMD] Family 14h Processor Root Port
00:05.0 PCI bridge: Advanced Micro Devices [AMD] Family 14h Processor Root Port
00:10.0 USB controller: Advanced Micro Devices [AMD] Hudson USB XHCI Controller (rev 03)
00:11.0 SATA controller: Advanced Micro Devices [AMD] Hudson SATA Controller [AHCI mode]
00:12.0 USB controller: Advanced Micro Devices [AMD] Hudson USB OHCI Controller (rev 11)
00:12.2 USB controller: Advanced Micro Devices [AMD] Hudson USB EHCI Controller (rev 11)
00:13.0 USB controller: Advanced Micro Devices [AMD] Hudson USB OHCI Controller (rev 11)
00:13.2 USB controller: Advanced Micro Devices [AMD] Hudson USB EHCI Controller (rev 11)
00:14.0 SMBus: Advanced Micro Devices [AMD] Hudson SMBus Controller (rev 14)
00:14.2 Audio device: Advanced Micro Devices [AMD] Hudson Azalia Controller (rev 01)
00:14.3 ISA bridge: Advanced Micro Devices [AMD] Hudson LPC Bridge (rev 11)
00:14.4 PCI bridge: Advanced Micro Devices [AMD] Hudson PCI Bridge (rev 40)
00:14.5 USB controller: Advanced Micro Devices [AMD] Hudson USB OHCI Controller (rev 11)
00:18.0 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 0 (rev 43)
00:18.1 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 1
00:18.2 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 2
00:18.3 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 3
00:18.4 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 4
00:18.5 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 6
00:18.6 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 5
00:18.7 Host bridge: Advanced Micro Devices [AMD] Family 12h/14h Processor Function 7
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 05)
02:00.0 Network controller: Broadcom Corporation BCM43228 802.11a/b/g/n
$ lsusb
'Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 04f2:b335 Chicony Electronics Co., Ltd
Does anyone have a suggestion as to how to get this sorted out? I have unfortunately been unable to find anymore information about the Bluetooth, neither on the Acer site nor on any of the sites that review the laptop.
BTW, I am also looking for a solution to the touchpad being locked at startup, requiring me to Fn-F7 unlock it at every system start. This issue is on all of the distros that I have tried (both 32 and 64 bit).
globetrotterdk
Postby wyliecoyoteuk » Sun Aug 05, 2012 8:30 am
I have had problems with Bluetooth on 12.04, specifically with a USB adapter that I have used for ages.
Bluetooth 4 is based on wifi, so may be built into the wifi adapter.
have you tried installing blueman ?
Postby globetrotterdk » Sun Aug 05, 2012 10:53 am
wyliecoyoteuk wrote:I have had problems with Bluetooth on 12.04, specifically with a USB adapter that I have used for ages.
Thanks for the reply. Blueman gets installed by default both with Lubuntu and Mageia, but the "adapter" and "device" menus are greyed out.
globetrotterdk
Postby wyliecoyoteuk » Sun Aug 05, 2012 1:11 pm
I know that on my lenovo laptop, the bluetooth and wifi are in one combined chip.
I haven't checked the bluetooth out, I'll try later if I get time.
Postby globetrotterdk » Sun Aug 05, 2012 10:11 pm
Sounds good. BTW, I just tried the following command and the Bluetooth device appears to be AWOL here as well:
$ hcitool dev
Devices:
globetrotterdk
Postby globetrotterdk » Sun Aug 05, 2012 10:32 pm
Looking at some more threads suggests that I should also post the following output:
rfkill list
0: brcmwl-0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: acer-wireless: Wireless LAN
Soft blocked: no
Hard blocked: no
2: acer-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
globetrotterdk
Postby wyliecoyoteuk » Mon Aug 06, 2012 2:22 pm
Just checked my Lenovo's bluetooth, works fine, but I did have to turn the wifi on in windows first.
Postby globetrotterdk » Mon Aug 06, 2012 3:51 pm
I have noticed that issue on a number of threads. My laptop came without Win. That was the whole point. I haven't been able to find a Linux based solution to this yet. There are some Ubuntu users that have apparently posted this as a bug already in 11.10. No response has been forthcoming from Ubuntu as far as I have been able to see :(
globetrotterdk
Postby towy71 » Mon Aug 06, 2012 6:05 pm
Could this be something that you need to turn on from the bios?
Postby wyliecoyoteuk » Mon Aug 06, 2012 7:07 pm
Unfortunately, the trend in laptops is to have as few physical buttons as possible.
my wifi button is F9, but that doesn't seem to work in Ubuntu.
Postby wyliecoyoteuk » Mon Aug 06, 2012 7:52 pm
http://hal.freedesktop.org/quirk/quirk-keymap-try.html
seems to point a way forward.
Edit:
I just ran updates (needed a lot, I don't update at work because the internet is sooo slow, and I don't use the laptop at home much).and now the f8 key toggles wifi on and off in Ubuntu.
Postby globetrotterdk » Tue Aug 07, 2012 8:01 am
wyliecoyoteuk wrote:http://hal.freedesktop.org/quirk/quirk-keymap-try.html
Edit:
I installed Windows 7 and all of the necessary drivers yesterday. I was then able to pair my Nokia Play 360 speakers. I booted into a Live CD, reduced the Win install and installed Peppermint OS Three (based on Lubuntu 12.04). Bluetooth 4.0 still doesn't work in Linux - the menus "adapter" and "device" are still greyed out in the Bluetooth Manager. I have run the commands again that I have run earlier to identify the device, however I have only found one change:
$ lsusb
Bus 004 Device 002: ID 0489:e046 Foxconn / Hon Hai
I still don't have much of an idea what is going on, but it seems like this remains first and foremost a hardware driver issue.
globetrotterdk
Users browsing this forum: Bing [Bot], Exabot [Bot], GeordieJedi and 2 guests
