Stay on page popup
PostPosted: Fri Aug 03, 2012 9:47 am    Post subject: Stay on page popup Reply with quote
Is there any way to permanently disable that awful "stay on page" popup that sometimes launches when you close a tab / navigate elsewhere?
Using Firefox 14.0.1 atm.
Ta.
AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
eeepc 1015PX, 1.66 Ghz Intel atom processor, 2 GB DDR3, 320 GB hd running Mint 14 MATE. Running great.
ajgreeny
PostPosted: Fri Aug 03, 2012 11:49 am    Post subject: Reply with quote
Try no-script add-on which should stop this happening. You may need to add trusted sites to its whitelist, or whatever it's called, but it is probably worth it.
Ubuntu 10.04 user, and loving it!
PostPosted: Fri Aug 03, 2012 12:37 pm    Post subject: Reply with quote
I think no-script is a bit too pre-emptive for me. I'm after something that works more like adblock - where it offers you the block option when it bumps into it, so you never have to again, rather than it blocks for you and then you find out your pages don't load properly and have to sort whitelists. Cheers
PostPosted: Fri Aug 03, 2012 3:53 pm    Post subject: Reply with quote
You maybe out of look as its not FF http://forums.mozillazine.org/viewtopic.php?f=7&t=2178527
