heiowge LXF regular
Joined: Wed Feb 27, 2008 8:21 pm Posts: 1794 Location: Cheshire, UK
Posted: Sun Jul 22, 2012 10:52 am Post subject: Black screen after 5 minutes of gaming |
Ok, I'm using windows for the games, but still it's a problem.
I've just dusted the PC and cleared the fans and vents when I fitted 2 new hard drives. I find it crashes playing Fallout New Vegas and Batman Arkham Asylum after a few minutes, but can play angry birds for hours.
I know fallout is unstable, but I never had a problem with Batman before.
I suspect it's a problem with my graphics card, but could do with advice.
Oh, and Linux doesn't crash!  _________________ AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
eeepc 1015PX, 1.66 Ghz Intel atom processor, 2 GB DDR3, 320 GB hd running Mint 14 MATE. Running great. |
bobthebob1234 LXF regular
Joined: Thu Jan 03, 2008 9:38 pm Posts: 1356 Location: A hole in a field
Posted: Sun Jul 22, 2012 12:36 pm Post subject: |
Overheating? Is there a temperature sensor on your graphics card that you can monitor whilst playing the games?
Which graphics card is it? Is there a known overheating problem? _________________ For certain you have to be lost to find the places that can't be found. Elseways, everyone would know where it was |
Bruno LXF regular
Joined: Tue Sep 18, 2007 7:07 pm Posts: 139 Location: Cambridgeshire, UK
Posted: Sun Jul 22, 2012 2:09 pm Post subject: |
| It is probably an overheating graphics card but it is worth checking that your PSU is able to handle the load attached to it. Have a look through the vents to see if any of the capacitors are "doming" on top or oozing anything from the top. |
Ram LXF regular
Joined: Thu Apr 07, 2005 10:44 pm Posts: 1547 Location: Guisborough
Posted: Sun Jul 22, 2012 10:36 pm Post subject: |
You could try and recreate it - try running glxgears in a terminal or 3
If you can't then I'd say software... _________________
heiowge LXF regular
Posted: Mon Jul 23, 2012 9:22 am Post subject: |
I think it might be a windows problem. Running Fallout New Vegas under wine runs for about an hour before crashing - about normal for FNV!  _________________ AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
Ram LXF regular
Posted: Mon Jul 23, 2012 1:11 pm Post subject: |
Have a look in the Application log it might give you an indication of the fault. _________________
Paradigm Shifter
Posted: Mon Jul 23, 2012 1:58 pm Post subject: |
What is the GPU itself? What is the PSU, and what is it rated at? (On 12v rail(s) etc?) If you've added new drives and a problem has appeared, it may suggest that when loaded there isn't quite enough power where there used to be.
If you took the HDD addition as an opportunity to update drivers too, that may have caused it. |
