Format a hard drive
PostPosted: Fri Jul 20, 2012 8:29 am    Post subject: Format a hard drive Reply with quote
I have a couple of new hard drives. One will be Windows 7 / Mint 13. The other one is a backup drive with storage that I need to access both OSes from.
Question: What is the best format to use on the backup to allow me to easily read / write / execute from both OSes?
Ta
AMD PHENOM II X6, 14 GB DDR3, 500 GB hd, 1GB nVidia card, running Linux Mint 14 KDE / Win 7. Damn thing keeps breaking.
eeepc 1015PX, 1.66 Ghz Intel atom processor, 2 GB DDR3, 320 GB hd running Mint 14 MATE. Running great.
PostPosted: Fri Jul 20, 2012 10:23 am    Post subject: Reply with quote
NTFS
or ext4 with Ext2Read installed on windows.
One problem is that the Windows NTFS permissions are not the same as Linux permissions. I would not recommend executing files from there, and you may have problems with backups if you want to retain file permissions.
