159 cover disc failure with win7, cure please
Postby norryP » Wed Jul 18, 2012 1:41 pm
HI I have tried to install the Ubuntu 12.04 LTS from the 159 cover disc alongside Windows 7 on a Toshiba Satellite C650. It seemed to go well, I ejected the disc and restarted the computer and GRUB was there to greet me. So far so good. I allowed the computer to boot into Ubuntu, then the trouble started. I had a screen come up that said that the system could not detect my screen, graphics card and hardware and that it was running in "low Graphics mode." to boot
I clicked OK and had several options.
1) Run in low-graphics mode for just one session
2)Configure graphics
3)Troubleshoot the error
4) Exit to console login
Options 1,2, and leads to the system freezing with the legend
Stopping system V runtime compatability [OK]
Ctrl+alt+del leads to a restart and the whole circus all over again.
Fortunately W7 is untroubled by all this and works just fine, I just have to select Windows in GRUB to have my old OS back up again.
Option 3 opens a recovery menu, on this menu is the option
dpkg Repair broken packages
select and enter brings up a screen that scrolls as the processes are run. Then at the top of the last page this:
W: Some index files failed to download. THey have been ignored or old ones used.
Calculating upgrade... Done
The following NEW packages will be installed.
linux-headers-3.2.0-24-generic-pae linux-image-3.2.0-24 generic-pae
The following packages will be upgraded.
linux-generic-pae linuc-headers-generic-pae linux-image-generic-pae
3 upgraded 2 newly installed, 0 to remove and 0 not upgraded.
Need to to get 38.8 MB of archives, after this operation 124MB of additional space will be used.
Do you wish to continue [Y/n}?
If I allow this operation will my Windows partition be safe? Or is the whole partition going to become a Linux partition?
I successfully loaded the Ubuntu Unity OS from the same disc on an old Desktop that I wanted to play around in Linux on, no problems with that installation it was seamless and trouble free. I am impressed with Linux and Open source stuff and have been moving away from MS products for a while now. I was hoping to abandon MS in favour of Ubuntu but this glitch is preventing me from making a permanent move.
So what is going on? and is there a solution to this? Will I be able to get to a functioning dual boot system?
Have found the answer!!
On the install process DO NOT import settings from windoze then the Linux OS installs as normal.
