duff
Posted: Fri Oct 28, 2005 2:13 pm Post subject: OOo speed ups |
Whilst browsing a couple of other sites I found these speed up tricks for OpenOffice.org.
Go to Tools / Options / Java and uncheck "Use a Java runtime environment".
This seemed to speed up my startup of OOo2 on a 1GHz Athlon with 1Gb RAM. I haven't lost any functionality yet and as far as I can gather Java is used for JDBC connections and little else in OOo. It's also reported as working in NeoOffice - the Mac Os X OOo port which I think does use Java more!
Go to Tools / Options / Memory and increase Graphics cache Use for Openoffice.org to 64Mb and Memory per object to 8Mb.
Let me know if anyone else notices any differences.
Cheers
Duff |
M-Saunders Moderator
Posted: Fri Oct 28, 2005 2:49 pm Post subject: RE: OOo speed ups |
I've tried those before, and have seen monitor. One of the problems with these tips is that people forget about (or aren't aware of) disk caching. They start OOo, which takes ages, then apply the tip and restart it straight away. Because OOo is still cached in RAM, it comes back up much quicker, so people assume the tip has worked wonders! Will be interesting to see the results others have...
M |
nelz Moderator
Posted: Fri Oct 28, 2005 2:59 pm Post subject: RE: OOo speed ups |
Unchecking Java definitely works, as I posted in here some months ago. ~~It reduced my OOo startup times to well under a minute! Impressive eh? _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
RDP
Posted: Sat Oct 29, 2005 3:32 pm Post subject: RE: OOo speed ups |
| If you don't want to loose Base and multimedia support on distros like Debian, that use a free version of Java that's _very_ slow, installing and using Sun's java makes it much quicker all round. |
RD LXF regular
Joined: Mon Jul 25, 2005 3:53 am Posts: 272 Location: irc.ixl2.net
Posted: Sat Oct 29, 2005 3:48 pm Post subject: RE: OOo speed ups |
Hmm, theres not much point to this as far as i can see as with just a standard OOo install i can open it up with a time of
12.60 Sec's after these little tweaks i can open it with a time of 8.17 sec's, i find that the first one is not bad at all and i dont this that the extra few secs of waiting time is that much of a problem  _________________ [url=irc://irc.ixl2.org/ixl2]irc.ixl2.org[/url] |
