Alex01UK
Joined: Thu Jun 14, 2012 5:31 pm Posts: 9 Location: United Kingdom
Posted: Sat Jun 16, 2012 10:22 am Post subject: How do I add the minimise/maximise ''buttons'' on GNOME 3? |
How do I add the minimise / maximise ''buttons'' on GNOME 3?
I know it's possible, as I managed to do this before. Had a perfect Ubuntu Linux setup with everything I need installed / working correctly, but I munged it when I removed my Open Suse 12.1 partition and had to install everything again.
aha, tia from Alex. _________________ ''I am what I am, because
we are what we are.'' |
Ram LXF regular
Joined: Thu Apr 07, 2005 10:44 pm Posts: 1547 Location: Guisborough
Posted: Sat Jun 16, 2012 12:59 pm Post subject: |
Try this site it's for Fedora but should work or at least jog your memory. _________________
Hammeh
Posted: Sun Jun 17, 2012 6:32 pm Post subject: Gnome-tweak |
You can also install gnome-tweak-tool which contains advanced options for altering the behavior of the shell.
You can install it via your graphical package manager or on the command line by:
Ubuntu: sudo apt-get install gnome-tweak-tool
Fedora: sudo yum install gnome-tweak-tool
openSUSE: sudo zypper in gnome-tweak-tool
Peter |
