mikejd LXF regular
Joined: Fri Apr 08, 2005 5:46 pm Posts: 129 Location: Huntly, Aberdeenshire
Posted: Fri Jun 08, 2012 4:20 pm Post subject: Unable to access internet over network |
I am running OpenSuse 11.4 and it has been running for some months. I have had no problem with internet or email until now.
I tried to install a virtual server, KVM, which required me to uninstall Skype due to conflicts. A lot of dependancies were installed. Now I cannot access either the internet or email.
The network is still working OK - I can connect to another machine and I can print to a network printer. In the browser I can log into the router. My other machine is accessing the internet without problem.
Something has been reconfigured or deleted/updated to prevent access. Can anyone advise how to sort this out, please?
Mike |
MartyBartfast LXF regular
Joined: Mon Aug 22, 2005 8:25 am Posts: 780 Location: Hants, UK
Posted: Fri Jun 08, 2012 4:46 pm Post subject: |
So in the browser you can get to your router, but can't get to any websites?
Could be DNS, can you get to websites using the IP address rather than name? e.g try http://212.58.244.67 which should get you to the BBC.
If not what errors do you get?
try openning a terminal and do
and see what you get. _________________ I have been touched by his noodly appendage. |
mikejd LXF regular
Posted: Fri Jun 08, 2012 4:55 pm Post subject: |
| Quote: | | Could be DNS, can you get to websites using the IP address rather than name? e.g try http://212.58.244.67 which should get you to the BBC. |
'Firefox cannot establish a connection to the server at 212.58.244.67.'
'Unable to connect to 212.58.244.67. Network is unreachable.'
Cheers,
Mike |
wyliecoyoteuk LXF regular
Joined: Sun Apr 10, 2005 11:41 pm Posts: 3358 Location: Birmingham, UK
Posted: Fri Jun 08, 2012 5:25 pm Post subject: |
If you installed KVM, you may have overwritten the routing table.
check that your gateway is the address of your router, and yuor DNS is correct.
look in /etc/network/interfaces and etc/resolv.conf _________________ The sig between the asterisks is so cool that only REALLY COOL people can even see it!
mikejd LXF regular
Posted: Fri Jun 08, 2012 5:48 pm Post subject: |
| Quote: | | look in /etc/network/interfaces and etc/resolv.conf |
I don't have /etc/network/.
/etc/resolve.conf has one entry:
'nameserver 192.168.1.1'
which is the router and is the same as /etc/resolve.conf on my other computer.
Mike |
mikejd LXF regular
Posted: Fri Jun 08, 2012 5:58 pm Post subject: |
Sorted!
I went to Network services in Yast, checked 'Routing'. It was blank.
Set gateway to router, and now everything works again.
Thanks all for assistance.
cheers,
Mike |
