Set up your Raspberry Pi like a pro
Postby einonm » Thu Jun 07, 2012 1:01 pm
Hi, I've written a quick guide on getting a decent set-up for development on a Raspberry Pi. Hope it proves useful to someone!
einonm
Postby Dutch_Master » Thu Jun 07, 2012 3:20 pm
Thanks for sharing :D However, in the section on connecting the RPi to a serial port, you assume the USB converter to be ttyUSB0. That may not always be the case, perhaps you could amend the entry to add a notice-with-solution if the user fails to connect.
Postby einonm » Thu Jun 07, 2012 4:43 pm
Dutch_Master wrote:Thanks for sharing :D However, in the section on connecting the RPi to a serial port, you assume the USB converter to be ttyUSB0. That may not always be the case, perhaps you could amend the entry to add a notice-with-solution if the user fails to connect.
You're welcome :)
Serial USB converters have never been any different on a Fedora machine in my experience since FC6 or so (and the post is written for a Fedora host). There's a possibility that a program could fail, holding ttyUSB0 and on a re-plug the device would get ttyUSB1 assigned to it, but that's quite unlikely.
Have you had a different experience with a USB serial device on Fedora?
einonm
Postby Dutch_Master » Thu Jun 07, 2012 5:02 pm
No, but that's because I don't use Fedora :P (Debian user here ;)) Neither do I have a serial<->USB converter... :mrgreen:
Postby Bazza » Fri Jun 08, 2012 6:18 pm
I ain't got mine yet! ;o(
About 5 weeks away, what, I could swim the Atlantic in that time...
Anyhow thanks for the pointer and no doubt I will use it...
As for /dev/ttyUSBx easy-peasy to solve...
73...
Team AMIGA...
Bazza
Return to Hints and tips
