acer aspire one & skype
Postby mikehoro » Wed Jun 06, 2012 4:41 pm
I have mint 13 & tried to get skype to work but cannot get the onboard mic to work.I have checked in puleaudio mixer & the mic is on but no joy. Any help most welcome Thanks
mikehoro
Postby arochester » Wed Jun 06, 2012 6:14 pm
Have you tried setting the sound IN Skype?
S Button(Bottom Left)>Options>Sound Devices
You may need to experiment with the drop-down settings for "Microphone"
arochester
Postby mikehoro » Wed Jun 06, 2012 8:25 pm
Yes tried all settings in skype.it does not seem to be registering with pulse.So I tried audacity to check the on board mic this works fine. So the problem is with skype i think
mikehoro
Postby einonm » Thu Jun 07, 2012 12:50 pm
I've had issues with Skype sound, but on Fedora. I managed to get it working by using alsamixer, a CLI tool that allows you to fiddle with settings for each sound card individually.
I think the issue is with the Gnome sound settings applet, it doesn't seem to attach the displayed volume controls/sliders to a different sound card when selected under the 'hardware' tab.
einonm
Postby mikehoro » Fri Jun 08, 2012 1:11 pm
The problem was solved by setting right mic channel to silence in pulse audio mixer & setting let skype control mixer to off (untick it)
Thanks for all your help
mikehoro
