A Python Metronome For Beginner Musicians...
Postby Bazza » Fri May 18, 2012 10:33 pm
Hi guys, not been around for a while but here is another freebie...
A simple metronome for beginner musicians to practice with.
# Metronome3x.py
# DEMO simple metronome that exploits a minor flaw in the /dev/audio and /dev/dsp devices inside Linux.
# It can tick at around 30 to 400 beats per minute. This minimal code can be improved upon to give
# greater accuracy, range and appearance on screen if required.
# Original copyright, (C)2007-2012, B.Walker, G0LCU. Now issued as Public Domain and you may do with
# it as you please.
# There is a small flaw that uses the Ctrl-C part of the code. I'll let the big guns tell you users
# that can't find it what it is. It is not a bug as such, but it is a flaw.
# Tested on an HP Notebook with Debian 6.0.0 and Python 3.1.3 and an Acer Aspire One Netbook with
# PCLinuxOS 2009 and Python 3.2.1.
# To run just type:-
# >>> exec(open("/absolute/path/to/Metronome3x.py").read())<RETURN/ENTER>
# And away you go...
# $VER: Metronome3x.py_Version_0.00.10_(C)2007-2012_B.Walker_G0LCU.
# Enjoy finding simple solutions to often very difficult problems...
# The only import(s) for this DEMO...
import time
import os
def main():
   while 1:
      # the _variable_ listing...
      # "n" is throw away integer number and purposely reused.
      # "beatstring" is the inputted string and is also reused.
      # "beat" is the floating point number from about 0.x to 1.x generated from the inputted data.
      # The standard Linux clear screen cmmand.
      n=os.system("clear")
      # Set up a basic user screen/window.
      print("\nPython 3.x.x simple metronome for the Linux platform.\n")
      print("(C)2007-2012, B.Walker, G0LCU. Issued as Public Domain.\n")
      beatstring=input("Enter any whole number from 30 to 400 (bpm), (QUIT or EXIT to Quit):- ")
      # Allow a means of quitting the DEMO.
      if beatstring=="QUIT" or beatstring=="EXIT": break
      # Don't allow any errors...
      if len(beatstring)>=4: beatstring="100"
      if len(beatstring)<=1: beatstring="100"
      n=0
      while n<=(len(beatstring)-1):
         if beatstring[n]>=chr(48) and beatstring[n]<=chr(57): n=n+1
         else: beatstring="100"
      n=int(beatstring)
      if n<=30: n=30
      if n>=400: n=400
      # Convert this integer "n" back to the "beatstring" string...
      beatstring=str(n)
      # Now convert to the floating point value for the time.sleep() function.
      beat=((60/n)-0.125)
      print("\nApproximate beats per minute = "+beatstring+"...\n")
      print("Press Ctrl-C to enter another speed...")
      while 1:
         # Write directly to the /dev/dsp device.
         try:
            audio=open("/dev/dsp", "wb")
            audio.write(b"\x00\xFF")
            audio.close()
            time.sleep(beat)
         # There is a flaw here, I'll let you big guns find it... ;o)
         # Note it is NOT really a bug!
         except KeyboardInterrupt: break
main()
# End of the Metronome3x.py code.
Have fun...
73...
Team AMIGA...
Bazza
