RichFox
Posted: Mon May 07, 2012 5:21 pm Post subject: problems with ./configure firestarter on ubuntu 11.10 |
Hi
I attempting to install Firestarter firestarter-1.0.3.tar.gz onto my laptop.
I have uncompressed files into a folder called 'source' and then changed to package directory and attempted '/config'.
After attempting config I get various error messages as I understand it that I am missing dependencies - but I believe that I have all the dependencies as I have installed or tried to install and then found that I allready have them.
I believe that something is either 'pointing' or 'looking' in the wrong place, but I am not technical when it comes to linux so I am a bit lost as to what to do.
I know that there are easier ways to install programs such as apt and synaptic but I just wish to be able to do so this way.
Details of my efforts below.
Thanks in advance for any help.
Rich
richard@richard-VGN-NR21M-S:~$ cd /home/richard
richard@richard-VGN-NR21M-S:~$ dir
brasero-session.log Downloads listing.txt Public Ubuntu\ One
Desktop e-books Music source Videos
dmesg.txt examples.desktop output Templates
Documents file Pictures testdisk.log
richard@richard-VGN-NR21M-S:~$ cd source
richard@richard-VGN-NR21M-S:~/source$ ls
firestarter-1.0.3
richard@richard-VGN-NR21M-S:~/source$ cd firestarter-1.0.3
richard@richard-VGN-NR21M-S:~/source/firestarter-1.0.3$ ls
aclocal.m4 COPYING INSTALL mkinstalldirs
AUTHORS CREDITS install-sh NEWS
autogen.sh fedora.init intltool-extract.in pixmaps
ChangeLog firestarter.console intltool-merge.in po
config.guess firestarter.desktop intltool-update.in README
config.h.in firestarter.desktop.in libtool scripts
config.log firestarter.pam ltmain.sh src
config.sub firestarter.schemas.in Makefile.am stamp-h.in
configure firestarter.spec Makefile.in TODO
configure.in firestarter.spec.in missing
richard@richard-VGN-NR21M-S:~/source/firestarter-1.0.3$ ./configure
checking for intltool >= 0.30... 0.31.2 found
checking for perl... /usr/bin/perl
checking for XML::Parser... ok
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets $(MAKE)... yes
checking for working aclocal-1.4... missing
checking for working autoconf... missing
checking for working automake-1.4... missing
checking for working autoheader... missing
checking for working makeinfo... missing
checking whether to enable maintainer-specific portions of Makefiles... no
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for library containing strerror... none required
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ANSI C... (cached) none needed
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking whether make sets $(MAKE)... (cached) yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for epcf90... no
checking for f95... no
checking for fort... no
checking for xlf95... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for gfortran... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether accepts -g... no
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc static flag works... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking what warning flags to pass to the C compiler... -Wall -Wmissing-prototypes
checking what language compliance flags to pass to the C compiler...
Using config source xml:merged:/etc/gconf/gconf.xml.defaults for schema installation
Using $(sysconfdir)/gconf/schemas as install directory for schema files
checking for gconftool-2... /usr/bin/gconftool-2
checking for pkg-config... /usr/bin/pkg-config
checking for libgnome-2.0 >= 2.0.0
libgnomeui-2.0 >= 2.0.0
gtk+-2.0 >= 2.4.0
gnome-vfs-2.0 >= 2.6.0
libglade-2.0 >= 2.3.6... Package libgnome-2.0 was not found in the pkg-config search path. Perhaps you should add the directory containing `libgnome-2.0.pc' to the PKG_CONFIG_PATH environment variable No package 'libgnome-2.0' found Package libgnomeui-2.0 was not found in the pkg-config search path. Perhaps you should add the directory containing `libgnomeui-2.0.pc' to the PKG_CONFIG_PATH environment variable No package 'libgnomeui-2.0' found Package gtk+-2.0 was not found in the pkg-config search path. Perhaps you should add the directory containing `gtk+-2.0.pc' to the PKG_CONFIG_PATH environment variable No package 'gtk+-2.0' found Package gnome-vfs-2.0 was not found in the pkg-config search path. Perhaps you should add the directory containing `gnome-vfs-2.0.pc' to the PKG_CONFIG_PATH environment variable No package 'gnome-vfs-2.0' found Package libglade-2.0 was not found in the pkg-config search path. Perhaps you should add the directory containing `libglade-2.0.pc' to the PKG_CONFIG_PATH environment variable No package 'libglade-2.0' found
configure: error: Library requirements (libgnome-2.0 >= 2.0.0
gtk+-2.0 >= 2.4.0
libglade-2.0 >= 2.3.6) not met; consider adjusting the PKG_CONFIG_PATH environment variable if your libraries are in a nonstandard prefix so pkg-config can find them.
richard@richard-VGN-NR21M-S:~/source/firestarter-1.0.3$ _________________ Thanks in advance for any help.
Rich |
Rhakios Moderator
Joined: Thu Apr 07, 2005 12:18 am Posts: 7484 Location: Midlands, UK
Posted: Mon May 07, 2012 6:11 pm Post subject: |
Obvious question, you are sure you have the libglade2-dev package installed? _________________ Bye, Rhakios |
RichFox
Posted: Mon May 07, 2012 7:47 pm Post subject: |
Thanks for your reply Rhaklos
I have just tried installing libglade2-dev package but it is already installed.
Details below:
richard@richard-VGN-NR21M-S:~$ sudo apt-get install libglade2-0
Reading package lists... Done
Building dependency tree
Reading state information... Done
libglade2-0 is already the newest version.
The following packages were automatically installed and are no longer required:
indicator-status-provider-pidgin pidgin-data
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
richard@richard-VGN-NR21M-S:~ -$
Thanks again for your reply.
Any help gratefully received.
Cheers
Rich |
nelz Moderator
Posted: Mon May 07, 2012 9:48 pm Post subject: |
libglade2 and libglade2-dev are different packages. The former, which you have installed, contains the program code and documentation, but the header files from the source code are in the -dev package. These are not needed when you use the software, which is why they are not installed by default, but they are needed when you want to compile another package against it.
Whenever ./configure complains that you are missing a package or library you know is installed, the solution is almost always to install the corresponding -dev (or -devel if you use an RPM distro) package. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
RichFox
Posted: Tue May 08, 2012 9:35 pm Post subject: |
Hi nelz
I have just tried installing libglade2-dev but it is all ready installed - please see below:
richard@richard-VGN-NR21M-S:~$ sudu apt-get install libglade2-dev
No command 'sudu' found, did you mean:
Command 'sudo' from package 'sudo' (main)
Command 'sudo' from package 'sudo-ldap' (universe)
Command 'tudu' from package 'tudu' (universe)
sudu: command not found
richard@richard-VGN-NR21M-S:~$ sudo apt-get install libglade2-dev
[sudo] password for richard:
libglade2-dev is already the newest version.
libglade2-dev set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
Thanks
Rich |
nelz Moderator
Posted: Wed May 09, 2012 12:18 am Post subject: |
Your output is complaining of other missing packages, such as libgnome-2.0 and libgtk+-2.0. Have you got the -dev packages installed for all of the complaints? _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
RichFox
Posted: Wed May 09, 2012 9:19 pm Post subject: |
Thanks nelz I have gone through and believe I have installed the dev files I also have installed lib files.
I have now attempted to ./configure - make - make install but firestarter is sill not installed.
Screen output below:
RESTARTER_RULES_DIR=\"/usr/local/etc\" -DGNOMELOCALEDIR=\""/usr/local/share/locale"\" -DGLADEDIR=\""/usr/local/share/firestarter/glade"\" -g -O2 -c menus.c
gcc -DHAVE_CONFIG_H -I. -I. -I.. -Wall -Wmissing-prototypes -pthread -DORBIT2=1 -D_REENTRANT -I/usr/include/glib-2.0 -I/usr/lib/i386-linux-gnu/glib-2.0/include -I/usr/include/dbus-1.0 -I/usr/lib/i386-linux-gnu/dbus-1.0/include -I/usr/include/gtk-2.0 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/gail-1.0 -I/usr/include/freetype2 -I/usr/include/atk-1.0 -I/usr/lib/i386-linux-gnu/gtk-2.0/include -I/usr/include/cairo -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/libpng12 -I/usr/include/libgnome-2.0 -I/usr/include/orbit-2.0 -I/usr/include/gconf/2 -I/usr/include/gnome-vfs-2.0 -I/usr/lib/gnome-vfs-2.0/include -I/usr/include/libbonobo-2.0 -I/usr/include/bonobo-activation-2.0 -I/usr/include/libgnomeui-2.0 -I/usr/include/libart-2.0 -I/usr/include/gnome-keyring-1 -I/usr/include/libbonoboui-2.0 -I/usr/include/libgnomecanvas-2.0 -I/usr/include/libxml2 -I/usr/include/libglade-2.0 -DG_LOG_DOMAIN=\"Firestarter\" -DFIRESTARTER_RULES_DIR=\"/usr/local/etc\" -DGNOMELOCALEDIR=\""/usr/local/share/locale"\" -DGLADEDIR=\""/usr/local/share/firestarter/glade"\" -g -O2 -c wizard.c
gcc -DHAVE_CONFIG_H -I. -I. -I.. -Wall -Wmissing-prototypes -pthread -DORBIT2=1 -D_REENTRANT -I/usr/include/glib-2.0 -I/usr/lib/i386-linux-gnu/glib-2.0/include -I/usr/include/dbus-1.0 -I/usr/lib/i386-linux-gnu/dbus-1.0/include -I/usr/include/gtk-2.0 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/gail-1.0 -I/usr/include/freetype2 -I/usr/include/atk-1.0 -I/usr/lib/i386-linux-gnu/gtk-2.0/include -I/usr/include/cairo -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/libpng12 -I/usr/include/libgnome-2.0 -I/usr/include/orbit-2.0 -I/usr/include/gconf/2 -I/usr/include/gnome-vfs-2.0 -I/usr/lib/gnome-vfs-2.0/include -I/usr/include/libbonobo-2.0 -I/usr/include/bonobo-activation-2.0 -I/usr/include/libgnomeui-2.0 -I/usr/include/libart-2.0 -I/usr/include/gnome-keyring-1 -I/usr/include/libbonoboui-2.0 -I/usr/include/libgnomecanvas-2.0 -I/usr/include/libxml2 -I/usr/include/libglade-2.0 -DG_LOG_DOMAIN=\"Firestarter\" -DFIRESTARTER_RULES_DIR=\"/usr/local/etc\" -DGNOMELOCALEDIR=\""/usr/local/share/locale"\" -DGLADEDIR=\""/usr/local/share/firestarter/glade"\" -g -O2 -c wizard-choices.c
gcc -DHAVE_CONFIG_H -I. -I. -I.. -Wall -Wmissing-prototypes -pthread -DORBIT2=1 -D_REENTRANT -I/usr/include/glib-2.0 -I/usr/lib/i386-linux-gnu/glib-2.0/include -I/usr/include/dbus-1.0 -I/usr/lib/i386-linux-gnu/dbus-1.0/include -I/usr/include/gtk-2.0 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/gail-1.0 -I/usr/include/freetype2 -I/usr/include/atk-1.0 -I/usr/lib/i386-linux-gnu/gtk-2.0/include -I/usr/include/cairo -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/libpng12 -I/usr/include/libgnome-2.0 -I/usr/include/orbit-2.0 -I/usr/include/gconf/2 -I/usr/include/gnome-vfs-2.0 -I/usr/lib/gnome-vfs-2.0/include -I/usr/include/libbonobo-2.0 -I/usr/include/bonobo-activation-2.0 -I/usr/include/libgnomeui-2.0 -I/usr/include/libart-2.0 -I/usr/include/gnome-keyring-1 -I/usr/include/libbonoboui-2.0 -I/usr/include/libgnomecanvas-2.0 -I/usr/include/libxml2 -I/usr/include/libglade-2.0 -DG_LOG_DOMAIN=\"Firestarter\" -DFIRESTARTER_RULES_DIR=\"/usr/local/etc\" -DGNOMELOCALEDIR=\""/usr/local/share/locale"\" -DGLADEDIR=\""/usr/local/share/firestarter/glade"\" -g -O2 -c service.c
service.c: In function ‘service_get_name’:
service.c:198:26: warning: comparison with string literal results in unspecified behavior [-Waddress]
gcc -DHAVE_CONFIG_H -I. -I. -I.. -Wall -Wmissing-prototypes -pthread -DORBIT2=1 -D_REENTRANT -I/usr/include/glib-2.0 -I/usr/lib/i386-linux-gnu/glib-2.0/include -I/usr/include/dbus-1.0 -I/usr/lib/i386-linux-gnu/dbus-1.0/include -I/usr/include/gtk-2.0 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/gail-1.0 -I/usr/include/freetype2 -I/usr/include/atk-1.0 -I/usr/lib/i386-linux-gnu/gtk-2.0/include -I/usr/include/cairo -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/libpng12 -I/usr/include/libgnome-2.0 -I/usr/include/orbit-2.0 -I/usr/include/gconf/2 -I/usr/include/gnome-vfs-2.0 -I/usr/lib/gnome-vfs-2.0/include -I/usr/include/libbonobo-2.0 -I/usr/include/bonobo-activation-2.0 -I/usr/include/libgnomeui-2.0 -I/usr/include/libart-2.0 -I/usr/include/gnome-keyring-1 -I/usr/include/libbonoboui-2.0 -I/usr/include/libgnomecanvas-2.0 -I/usr/include/libxml2 -I/usr/include/libglade-2.0 -DG_LOG_DOMAIN=\"Firestarter\" -DFIRESTARTER_RULES_DIR=\"/usr/local/etc\" -DGNOMELOCALEDIR=\""/usr/local/share/locale"\" -DGLADEDIR=\""/usr/local/share/firestarter/glade"\" -g -O2 -c preferences.c
preferences.c: In function ‘preferences_check_schema’:
preferences.c:164:43: warning: format not a string literal and no format arguments [-Wformat-security]
gcc -DHAVE_CONFIG_H -I. -I. -I.. -Wall -Wmissing-prototypes -pthread -DORBIT2=1 -D_REENTRANT -I/usr/include/glib-2.0 -I/usr/lib/i386-linux-gnu/glib-2.0/include -I/usr/include/dbus-1.0 -I/usr/lib/i386-linux-gnu/dbus-1.0/include -I/usr/include/gtk-2.0 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/gail-1.0 -I/usr/include/freetype2 -I/usr/include/atk-1.0 -I/usr/lib/i386-linux-gnu/gtk-2.0/include -I/usr/include/cairo -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/libpng12 -I/usr/include/libgnome-2.0 -I/usr/include/orbit-2.0 -I/usr/include/gconf/2 -I/usr/include/gnome-vfs-2.0 -I/usr/lib/gnome-vfs-2.0/include -I/usr/include/libbonobo-2.0 -I/usr/include/bonobo-activation-2.0 -I/usr/include/libgnomeui-2.0 -I/usr/include/libart-2.0 -I/usr/include/gnome-keyring-1 -I/usr/include/libbonoboui-2.0 -I/usr/include/libgnomecanvas-2.0 -I/usr/include/libxml2 -I/usr/include/libglade-2.0 -DG_LOG_DOMAIN=\"Firestarter\" -DFIRESTARTER_RULES_DIR=\"/usr/local/etc\" -DGNOMELOCALEDIR=\""/usr/local/share/locale"\" -DGLADEDIR=\""/usr/local/share/firestarter/glade"\" -g -O2 -c scriptwriter.c
scriptwriter.c: In function ‘append_hook_to_script’:
scriptwriter.c:494:2: warning: format not a string literal and no format arguments [-Wformat-security]
scriptwriter.c:498:3: warning: format not a string literal and no format arguments [-Wformat-security]
scriptwriter.c: In function ‘remove_hook’:
scriptwriter.c:547:4: warning: format not a string literal and no format arguments [-Wformat-security]
scriptwriter.c: In function ‘add_hook’:
scriptwriter.c:583:3: warning: format not a string literal and no format arguments [-Wformat-security]
scriptwriter.c: In function ‘scriptwriter_versions_match’:
scriptwriter.c:767:8: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result [-Wunused-result]
gcc -DHAVE_CONFIG_H -I. -I. -I.. -Wall -Wmissing-prototypes -pthread -DORBIT2=1 -D_REENTRANT -I/usr/include/glib-2.0 -I/usr/lib/i386-linux-gnu/glib-2.0/include -I/usr/include/dbus-1.0 -I/usr/lib/i386-linux-gnu/dbus-1.0/include -I/usr/include/gtk-2.0 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/gail-1.0 -I/usr/include/freetype2 -I/usr/include/atk-1.0 -I/usr/lib/i386-linux-gnu/gtk-2.0/include -I/usr/include/cairo -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/libpng12 -I/usr/include/libgnome-2.0 -I/usr/include/orbit-2.0 -I/usr/include/gconf/2 -I/usr/include/gnome-vfs-2.0 -I/usr/lib/gnome-vfs-2.0/include -I/usr/include/libbonobo-2.0 -I/usr/include/bonobo-activation-2.0 -I/usr/include/libgnomeui-2.0 -I/usr/include/libart-2.0 -I/usr/include/gnome-keyring-1 -I/usr/include/libbonoboui-2.0 -I/usr/include/libgnomecanvas-2.0 -I/usr/include/libxml2 -I/usr/include/libglade-2.0 -DG_LOG_DOMAIN=\"Firestarter\" -DFIRESTARTER_RULES_DIR=\"/usr/local/etc\" -DGNOMELOCALEDIR=\""/usr/local/share/locale"\" -DGLADEDIR=\""/usr/local/share/firestarter/glade"\" -g -O2 -c savelog.c
gcc -DHAVE_CONFIG_H -I. -I. -I.. -Wall -Wmissing-prototypes -pthread -DORBIT2=1 -D_REENTRANT -I/usr/include/glib-2.0 -I/usr/lib/i386-linux-gnu/glib-2.0/include -I/usr/include/dbus-1.0 -I/usr/lib/i386-linux-gnu/dbus-1.0/include -I/usr/include/gtk-2.0 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/gail-1.0 -I/usr/include/freetype2 -I/usr/include/atk-1.0 -I/usr/lib/i386-linux-gnu/gtk-2.0/include -I/usr/include/cairo -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/libpng12 -I/usr/include/libgnome-2.0 -I/usr/include/orbit-2.0 -I/usr/include/gconf/2 -I/usr/include/gnome-vfs-2.0 -I/usr/lib/gnome-vfs-2.0/include -I/usr/include/libbonobo-2.0 -I/usr/include/bonobo-activation-2.0 -I/usr/include/libgnomeui-2.0 -I/usr/include/libart-2.0 -I/usr/include/gnome-keyring-1 -I/usr/include/libbonoboui-2.0 -I/usr/include/libgnomecanvas-2.0 -I/usr/include/libxml2 -I/usr/include/libglade-2.0 -DG_LOG_DOMAIN=\"Firestarter\" -DFIRESTARTER_RULES_DIR=\"/usr/local/etc\" -DGNOMELOCALEDIR=\""/usr/local/share/locale"\" -DGLADEDIR=\""/usr/local/share/firestarter/glade"\" -g -O2 -c netfilter-script.c
gcc -DHAVE_CONFIG_H -I. -I. -I.. -Wall -Wmissing-prototypes -pthread -DORBIT2=1 -D_REENTRANT -I/usr/include/glib-2.0 -I/usr/lib/i386-linux-gnu/glib-2.0/include -I/usr/include/dbus-1.0 -I/usr/lib/i386-linux-gnu/dbus-1.0/include -I/usr/include/gtk-2.0 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/gail-1.0 -I/usr/include/freetype2 -I/usr/include/atk-1.0 -I/usr/lib/i386-linux-gnu/gtk-2.0/include -I/usr/include/cairo -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/libpng12 -I/usr/include/libgnome-2.0 -I/usr/include/orbit-2.0 -I/usr/include/gconf/2 -I/usr/include/gnome-vfs-2.0 -I/usr/lib/gnome-vfs-2.0/include -I/usr/include/libbonobo-2.0 -I/usr/include/bonobo-activation-2.0 -I/usr/include/libgnomeui-2.0 -I/usr/include/libart-2.0 -I/usr/include/gnome-keyring-1 -I/usr/include/libbonoboui-2.0 -I/usr/include/libgnomecanvas-2.0 -I/usr/include/libxml2 -I/usr/include/libglade-2.0 -DG_LOG_DOMAIN=\"Firestarter\" -DFIRESTARTER_RULES_DIR=\"/usr/local/etc\" -DGNOMELOCALEDIR=\""/usr/local/share/locale"\" -DGLADEDIR=\""/usr/local/share/firestarter/glade"\" -g -O2 -c hitview.c
gcc -DHAVE_CONFIG_H -I. -I. -I.. -Wall -Wmissing-prototypes -pthread -DORBIT2=1 -D_REENTRANT -I/usr/include/glib-2.0 -I/usr/lib/i386-linux-gnu/glib-2.0/include -I/usr/include/dbus-1.0 -I/usr/lib/i386-linux-gnu/dbus-1.0/include -I/usr/include/gtk-2.0 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/gail-1.0 -I/usr/include/freetype2 -I/usr/include/atk-1.0 -I/usr/lib/i386-linux-gnu/gtk-2.0/include -I/usr/include/cairo -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/libpng12 -I/usr/include/libgnome-2.0 -I/usr/include/orbit-2.0 -I/usr/include/gconf/2 -I/usr/include/gnome-vfs-2.0 -I/usr/lib/gnome-vfs-2.0/include -I/usr/include/libbonobo-2.0 -I/usr/include/bonobo-activation-2.0 -I/usr/include/libgnomeui-2.0 -I/usr/include/libart-2.0 -I/usr/include/gnome-keyring-1 -I/usr/include/libbonoboui-2.0 -I/usr/include/libgnomecanvas-2.0 -I/usr/include/libxml2 -I/usr/include/libglade-2.0 -DG_LOG_DOMAIN=\"Firestarter\" -DFIRESTARTER_RULES_DIR=\"/usr/local/etc\" -DGNOMELOCALEDIR=\""/usr/local/share/locale"\" -DGLADEDIR=\""/usr/local/share/firestarter/glade"\" -g -O2 -c eggtrayicon.c
gcc -DHAVE_CONFIG_H -I. -I. -I.. -Wall -Wmissing-prototypes -pthread -DORBIT2=1 -D_REENTRANT -I/usr/include/glib-2.0 -I/usr/lib/i386-linux-gnu/glib-2.0/include -I/usr/include/dbus-1.0 -I/usr/lib/i386-linux-gnu/dbus-1.0/include -I/usr/include/gtk-2.0 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/gail-1.0 -I/usr/include/freetype2 -I/usr/include/atk-1.0 -I/usr/lib/i386-linux-gnu/gtk-2.0/include -I/usr/include/cairo -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/libpng12 -I/usr/include/libgnome-2.0 -I/usr/include/orbit-2.0 -I/usr/include/gconf/2 -I/usr/include/gnome-vfs-2.0 -I/usr/lib/gnome-vfs-2.0/include -I/usr/include/libbonobo-2.0 -I/usr/include/bonobo-activation-2.0 -I/usr/include/libgnomeui-2.0 -I/usr/include/libart-2.0 -I/usr/include/gnome-keyring-1 -I/usr/include/libbonoboui-2.0 -I/usr/include/libgnomecanvas-2.0 -I/usr/include/libxml2 -I/usr/include/libglade-2.0 -DG_LOG_DOMAIN=\"Firestarter\" -DFIRESTARTER_RULES_DIR=\"/usr/local/etc\" -DGNOMELOCALEDIR=\""/usr/local/share/locale"\" -DGLADEDIR=\""/usr/local/share/firestarter/glade"\" -g -O2 -c tray.c
gcc -DHAVE_CONFIG_H -I. -I. -I.. -Wall -Wmissing-prototypes -pthread -DORBIT2=1 -D_REENTRANT -I/usr/include/glib-2.0 -I/usr/lib/i386-linux-gnu/glib-2.0/include -I/usr/include/dbus-1.0 -I/usr/lib/i386-linux-gnu/dbus-1.0/include -I/usr/include/gtk-2.0 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/gail-1.0 -I/usr/include/freetype2 -I/usr/include/atk-1.0 -I/usr/lib/i386-linux-gnu/gtk-2.0/include -I/usr/include/cairo -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/libpng12 -I/usr/include/libgnome-2.0 -I/usr/include/orbit-2.0 -I/usr/include/gconf/2 -I/usr/include/gnome-vfs-2.0 -I/usr/lib/gnome-vfs-2.0/include -I/usr/include/libbonobo-2.0 -I/usr/include/bonobo-activation-2.0 -I/usr/include/libgnomeui-2.0 -I/usr/include/libart-2.0 -I/usr/include/gnome-keyring-1 -I/usr/include/libbonoboui-2.0 -I/usr/include/libgnomecanvas-2.0 -I/usr/include/libxml2 -I/usr/include/libglade-2.0 -DG_LOG_DOMAIN=\"Firestarter\" -DFIRESTARTER_RULES_DIR=\"/usr/local/etc\" -DGNOMELOCALEDIR=\""/usr/local/share/locale"\" -DGLADEDIR=\""/usr/local/share/firestarter/glade"\" -g -O2 -c dhcp-server.c
gcc -DHAVE_CONFIG_H -I. -I. -I.. -Wall -Wmissing-prototypes -pthread -DORBIT2=1 -D_REENTRANT -I/usr/include/glib-2.0 -I/usr/lib/i386-linux-gnu/glib-2.0/include -I/usr/include/dbus-1.0 -I/usr/lib/i386-linux-gnu/dbus-1.0/include -I/usr/include/gtk-2.0 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/gail-1.0 -I/usr/include/freetype2 -I/usr/include/atk-1.0 -I/usr/lib/i386-linux-gnu/gtk-2.0/include -I/usr/include/cairo -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/libpng12 -I/usr/include/libgnome-2.0 -I/usr/include/orbit-2.0 -I/usr/include/gconf/2 -I/usr/include/gnome-vfs-2.0 -I/usr/lib/gnome-vfs-2.0/include -I/usr/include/libbonobo-2.0 -I/usr/include/bonobo-activation-2.0 -I/usr/include/libgnomeui-2.0 -I/usr/include/libart-2.0 -I/usr/include/gnome-keyring-1 -I/usr/include/libbonoboui-2.0 -I/usr/include/libgnomecanvas-2.0 -I/usr/include/libxml2 -I/usr/include/libglade-2.0 -DG_LOG_DOMAIN=\"Firestarter\" -DFIRESTARTER_RULES_DIR=\"/usr/local/etc\" -DGNOMELOCALEDIR=\""/usr/local/share/locale"\" -DGLADEDIR=\""/usr/local/share/firestarter/glade"\" -g -O2 -c statusview.c
gcc -DHAVE_CONFIG_H -I. -I. -I.. -Wall -Wmissing-prototypes -pthread -DORBIT2=1 -D_REENTRANT -I/usr/include/glib-2.0 -I/usr/lib/i386-linux-gnu/glib-2.0/include -I/usr/include/dbus-1.0 -I/usr/lib/i386-linux-gnu/dbus-1.0/include -I/usr/include/gtk-2.0 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/gail-1.0 -I/usr/include/freetype2 -I/usr/include/atk-1.0 -I/usr/lib/i386-linux-gnu/gtk-2.0/include -I/usr/include/cairo -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/libpng12 -I/usr/include/libgnome-2.0 -I/usr/include/orbit-2.0 -I/usr/include/gconf/2 -I/usr/include/gnome-vfs-2.0 -I/usr/lib/gnome-vfs-2.0/include -I/usr/include/libbonobo-2.0 -I/usr/include/bonobo-activation-2.0 -I/usr/include/libgnomeui-2.0 -I/usr/include/libart-2.0 -I/usr/include/gnome-keyring-1 -I/usr/include/libbonoboui-2.0 -I/usr/include/libgnomecanvas-2.0 -I/usr/include/libxml2 -I/usr/include/libglade-2.0 -DG_LOG_DOMAIN=\"Firestarter\" -DFIRESTARTER_RULES_DIR=\"/usr/local/etc\" -DGNOMELOCALEDIR=\""/usr/local/share/locale"\" -DGLADEDIR=\""/usr/local/share/firestarter/glade"\" -g -O2 -c policyview.c
policyview.c: In function ‘unescape_string’:
policyview.c:304:6: warning: value computed is not used [-Wunused-value]
/bin/bash ../libtool --mode=link gcc -g -O2 -o firestarter firestarter.o gui.o util.o logread.o menus.o wizard.o wizard-choices.o service.o preferences.o scriptwriter.o savelog.o netfilter-script.o hitview.o eggtrayicon.o tray.o dhcp-server.o statusview.o policyview.o -pthread -lgnomeui-2 -lSM -lICE -lbonoboui-2 -lgnomecanvas-2 -lgnome-2 -lpopt -lbonobo-2 -lbonobo-activation -lORBit-2 -lart_lgpl_2 -lgnomevfs-2 -lgconf-2 -lglade-2.0 -lgtk-x11-2.0 -lxml2 -lgdk-x11-2.0 -latk-1.0 -lgio-2.0 -lpangoft2-1.0 -lpangocairo-1.0 -lgdk_pixbuf-2.0 -lcairo -lpango-1.0 -lfreetype -lfontconfig -lgobject-2.0 -lgmodule-2.0 -lgthread-2.0 -lrt -lglib-2.0
mkdir .libs
gcc -g -O2 -o firestarter firestarter.o gui.o util.o logread.o menus.o wizard.o wizard-choices.o service.o preferences.o scriptwriter.o savelog.o netfilter-script.o hitview.o eggtrayicon.o tray.o dhcp-server.o statusview.o policyview.o -pthread -lgnomeui-2 -lSM -lICE /usr/lib/libbonoboui-2.so -lgnomecanvas-2 /usr/lib/libgnome-2.so /usr/lib/libpopt.so /usr/lib/libbonobo-2.so /usr/lib/libbonobo-activation.so /usr/lib/libORBit-2.so /usr/lib/libart_lgpl_2.so /usr/lib/libgnomevfs-2.so /usr/lib/libgconf-2.so /usr/lib/libglade-2.0.so /usr/lib/i386-linux-gnu/libgtk-x11-2.0.so /usr/lib/libxml2.so /usr/lib/i386-linux-gnu/libgdk-x11-2.0.so /usr/lib/i386-linux-gnu/libatk-1.0.so /usr/lib/i386-linux-gnu/libgio-2.0.so /usr/lib/i386-linux-gnu/libpangoft2-1.0.so /usr/lib/i386-linux-gnu/libpangocairo-1.0.so -lgdk_pixbuf-2.0 /usr/lib/i386-linux-gnu/libcairo.so /usr/lib/i386-linux-gnu/libpango-1.0.so /usr/lib/i386-linux-gnu/libfreetype.so -lfontconfig /usr/lib/i386-linux-gnu/libgobject-2.0.so /usr/lib/i386-linux-gnu/libgmodule-2.0.so /usr/lib/i386-linux-gnu/libgthread-2.0.so -lrt /usr/lib/i386-linux-gnu/libglib-2.0.so -Wl,--rpath -Wl,/usr/lib/i386-linux-gnu -Wl,--rpath -Wl,/usr/lib/i386-linux-gnu
/usr/bin/ld: eggtrayicon.o: undefined reference to symbol 'XFlush'
/usr/bin/ld: note: 'XFlush' is defined in DSO /usr/lib/i386-linux-gnu/libX11.so.6 so try adding it to the linker command line
/usr/lib/i386-linux-gnu/libX11.so.6: could not read symbols: Invalid operation
collect2: ld returned 1 exit status
make[3]: *** [firestarter] Error 1
make[3]: Leaving directory `/home/richard/source/firestarter-1.0.3/src'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/richard/source/firestarter-1.0.3/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/richard/source/firestarter-1.0.3'
make: *** [all-recursive-am] Error 2
richard@richard-VGN-NR21M-S:~/source/firestarter-1.0.3$ make install
Making install in po
make[1]: Entering directory `/home/richard/source/firestarter-1.0.3/po'
if test -r ".././mkinstalldirs"; then \
.././mkinstalldirs /usr/local/share; \
else \
/bin/sh ../mkinstalldirs /usr/local/share; \
fi
mkdir -p -- /usr/local/share/locale/az/LC_MESSAGES
mkdir: cannot create directory `/usr/local/share/locale': Permission denied
/usr/bin/install: cannot create regular file `/usr/local/share/locale/az/LC_MESSAGES/firestarter.mo': No such file or directory
installing az.gmo as /usr/local/share/locale/az/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/ca/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/ca/LC_MESSAGES/firestarter.mo': No such file or directory
installing ca.gmo as /usr/local/share/locale/ca/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/cs/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/cs/LC_MESSAGES/firestarter.mo': No such file or directory
installing cs.gmo as /usr/local/share/locale/cs/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/da/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/da/LC_MESSAGES/firestarter.mo': No such file or directory
installing da.gmo as /usr/local/share/locale/da/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/de/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/de/LC_MESSAGES/firestarter.mo': No such file or directory
installing de.gmo as /usr/local/share/locale/de/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/el/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/el/LC_MESSAGES/firestarter.mo': No such file or directory
installing el.gmo as /usr/local/share/locale/el/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/en_CA/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/en_CA/LC_MESSAGES/firestarter.mo': No such file or directory
installing en_CA.gmo as /usr/local/share/locale/en_CA/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/en_GB/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/en_GB/LC_MESSAGES/firestarter.mo': No such file or directory
installing en_GB.gmo as /usr/local/share/locale/en_GB/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/es/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/es/LC_MESSAGES/firestarter.mo': No such file or directory
installing es.gmo as /usr/local/share/locale/es/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/fi/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/fi/LC_MESSAGES/firestarter.mo': No such file or directory
installing fi.gmo as /usr/local/share/locale/fi/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/fr/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/fr/LC_MESSAGES/firestarter.mo': No such file or directory
installing fr.gmo as /usr/local/share/locale/fr/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/ga/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/ga/LC_MESSAGES/firestarter.mo': No such file or directory
installing ga.gmo as /usr/local/share/locale/ga/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/hr/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/hr/LC_MESSAGES/firestarter.mo': No such file or directory
installing hr.gmo as /usr/local/share/locale/hr/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/hu/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/hu/LC_MESSAGES/firestarter.mo': No such file or directory
installing hu.gmo as /usr/local/share/locale/hu/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/it/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/it/LC_MESSAGES/firestarter.mo': No such file or directory
installing it.gmo as /usr/local/share/locale/it/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/ja/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/ja/LC_MESSAGES/firestarter.mo': No such file or directory
installing ja.gmo as /usr/local/share/locale/ja/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/ko/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/ko/LC_MESSAGES/firestarter.mo': No such file or directory
installing ko.gmo as /usr/local/share/locale/ko/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/lv/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/lv/LC_MESSAGES/firestarter.mo': No such file or directory
installing lv.gmo as /usr/local/share/locale/lv/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/ml/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/ml/LC_MESSAGES/firestarter.mo': No such file or directory
installing ml.gmo as /usr/local/share/locale/ml/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/nb/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/nb/LC_MESSAGES/firestarter.mo': No such file or directory
installing nb.gmo as /usr/local/share/locale/nb/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/nl/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/nl/LC_MESSAGES/firestarter.mo': No such file or directory
installing nl.gmo as /usr/local/share/locale/nl/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/no/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/no/LC_MESSAGES/firestarter.mo': No such file or directory
installing no.gmo as /usr/local/share/locale/no/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/pa/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/pa/LC_MESSAGES/firestarter.mo': No such file or directory
installing pa.gmo as /usr/local/share/locale/pa/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/pl/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/pl/LC_MESSAGES/firestarter.mo': No such file or directory
installing pl.gmo as /usr/local/share/locale/pl/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/pt/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/pt/LC_MESSAGES/firestarter.mo': No such file or directory
installing pt.gmo as /usr/local/share/locale/pt/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/pt_BR/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/pt_BR/LC_MESSAGES/firestarter.mo': No such file or directory
installing pt_BR.gmo as /usr/local/share/locale/pt_BR/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/ro/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/ro/LC_MESSAGES/firestarter.mo': No such file or directory
installing ro.gmo as /usr/local/share/locale/ro/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/ru/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/ru/LC_MESSAGES/firestarter.mo': No such file or directory
installing ru.gmo as /usr/local/share/locale/ru/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/sk/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/sk/LC_MESSAGES/firestarter.mo': No such file or directory
installing sk.gmo as /usr/local/share/locale/sk/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/sq/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/sq/LC_MESSAGES/firestarter.mo': No such file or directory
installing sq.gmo as /usr/local/share/locale/sq/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/sr/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/sr/LC_MESSAGES/firestarter.mo': No such file or directory
installing sr.gmo as /usr/local/share/locale/sr/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/sr@Latn/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/sr@Latn/LC_MESSAGES/firestarter.mo': No such file or directory
installing sr@Latn.gmo as /usr/local/share/locale/sr@Latn/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/sv/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/sv/LC_MESSAGES/firestarter.mo': No such file or directory
installing sv.gmo as /usr/local/share/locale/sv/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/tr/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/tr/LC_MESSAGES/firestarter.mo': No such file or directory
installing tr.gmo as /usr/local/share/locale/tr/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/uk/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/uk/LC_MESSAGES/firestarter.mo': No such file or directory
installing uk.gmo as /usr/local/share/locale/uk/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/vi/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/vi/LC_MESSAGES/firestarter.mo': No such file or directory
installing vi.gmo as /usr/local/share/locale/vi/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/zh_CN/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/zh_CN/LC_MESSAGES/firestarter.mo': No such file or directory
installing zh_CN.gmo as /usr/local/share/locale/zh_CN/LC_MESSAGES/firestarter.mo
mkdir -p -- /usr/local/share/locale/zh_TW/LC_MESSAGES
/usr/bin/install: cannot create regular file `/usr/local/share/locale/zh_TW/LC_MESSAGES/firestarter.mo': No such file or directory
installing zh_TW.gmo as /usr/local/share/locale/zh_TW/LC_MESSAGES/firestarter.mo
if test "firestarter" = "glib"; then \
.././mkinstalldirs /usr/local/share/glib-2.0/gettext/po; \
else \
/bin/sh ../mkinstalldirs /usr/local/share/glib-2.0/gettext/po; \
fi; \
/usr/bin/install -c -m 644 ./Makefile.in.in \
/usr/local/share/glib-2.0/gettext/po/Makefile.in.in; \
else \
fi
make[1]: Leaving directory `/home/richard/source/firestarter-1.0.3/po'
Making install in src
make[1]: Entering directory `/home/richard/source/firestarter-1.0.3/src'
Making install in xpm
make[2]: Entering directory `/home/richard/source/firestarter-1.0.3/src/xpm'
make[3]: Entering directory `/home/richard/source/firestarter-1.0.3/src/xpm'
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/home/richard/source/firestarter-1.0.3/src/xpm'
make[2]: Leaving directory `/home/richard/source/firestarter-1.0.3/src/xpm'
make[2]: Entering directory `/home/richard/source/firestarter-1.0.3/src'
make[2]: *** [firestarter] Error 1
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/home/richard/source/firestarter-1.0.3/src'
make: *** [install-recursive] Error 1
richard@richard-VGN-NR21M-S:~/source/firestarter-1.0.3$ cd
richard@richard-VGN-NR21M-S:~$ firestarter
The program 'firestarter' is currently not installed. You can install it by typing:
sudo apt-get install firestarter
Thanks Rich |
nelz Moderator
Posted: Wed May 09, 2012 10:18 pm Post subject: |
I see no output from ./configure, but it's not easy to read when you don't use code tags. makeinstall failed becaue it needs to be run as root, or with sudo, but there's no point in running it if make fails. Can you post, in code tags, the output from
| Code: | | ./configure && make && sudo make install |
The && links mean a command has to succeed before the next one is run, so it will stop at the first error. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
RichFox
Posted: Thu May 10, 2012 8:27 pm Post subject: |
Hi nelz - thanks for your conyinued help.
I have run
#./configure && make && sudo make install
and here is the output - apologies but I am a bit unsure about how to use code marks so sorry if I get wrong.
| Code: | | richard@richard-VGN-NR21M-S:~$ cd home/richard/source |
| Code: | | bash: cd: home/richard/source: No such file or directory |
| Code: | | richard@richard-VGN-NR21M-S:~$ cd |
| Code: | | richard@richard-VGN-NR21M-S:~$ cd home/richard |
| Code: | | bash: cd: home/richard: No such file or directory |
richard@richard-VGN-NR21M-S:~$ ls
brasero-session.log Documents file Pictures Templates
chmodexercise.text Downloads listing.txt Public testdisk.log
Desktop e-books Music source Ubuntu One
dmesg.txt examples.desktop output teachmod Videos
| Code: | | richard@richard-VGN-NR21M-S:~$ cd /home/richard/source |
| Code: | | richard@richard-VGN-NR21M-S:~/source$ cd .. |
| Code: | | richard@richard-VGN-NR21M-S:~/source$ ls |
firestarter-1.0.3
| Code: | | richard@richard-VGN-NR21M-S:~/source$ cd firestarter-1.0.3 |
| Code: | | richard@richard-VGN-NR21M-S:~/source/firestarter-1.0.3$ |
checking for working autoconf... found
checking for working autoheader... found
gtk+-2.0 >= 2.4.0
libglade-2.0 >= 2.3.6... yes
checking FIRESTARTER_CFLAGS... -pthread -DORBIT2=1 -D_REENTRANT -I/usr/include/glib-2.0 -I/usr/lib/i386-linux-gnu/glib-2.0/include -I/usr/include/dbus-1.0 -I/usr/lib/i386-linux-gnu/dbus-1.0/include -I/usr/include/gtk-2.0 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/gail-1.0 -I/usr/include/freetype2 -I/usr/include/atk-1.0 -I/usr/lib/i386-linux-gnu/gtk-2.0/include -I/usr/include/cairo -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/libpng12 -I/usr/include/libgnome-2.0 -I/usr/include/orbit-2.0 -I/usr/include/gconf/2 -I/usr/include/gnome-vfs-2.0 -I/usr/lib/gnome-vfs-2.0/include -I/usr/include/libbonobo-2.0 -I/usr/include/bonobo-activation-2.0 -I/usr/include/libgnomeui-2.0 -I/usr/include/libart-2.0 -I/usr/include/gnome-keyring-1 -I/usr/include/libbonoboui-2.0 -I/usr/include/libgnomecanvas-2.0 -I/usr/include/libxml2 -I/usr/include/libglade-2.0
checking FIRESTARTER_LIBS... -pthread -lgnomeui-2 -lSM -lICE -lbonoboui-2 -lgnomecanvas-2 -lgnome-2 -lpopt -lbonobo-2 -lbonobo-activation -lORBit-2 -lart_lgpl_2 -lgnomevfs-2 -lgconf-2 -lglade-2.0 -lgtk-x11-2.0 -lxml2 -lgdk-x11-2.0 -latk-1.0 -lgio-2.0 -lpangoft2-1.0 -lpangocairo-1.0 -lgdk_pixbuf-2.0 -lcairo -lpango-1.0 -lfreetype -lfontconfig -lgobject-2.0 -lgmodule-2.0 -lgthread-2.0 -lrt -lglib-2.0
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking for LC_MESSAGES... yes
checking libintl.h usability... yes
checking libintl.h presence... yes
checking for libintl.h... yes
checking for dgettext in libc... yes
checking for bind_textdomain_codeset... yes
checking for msgfmt... /usr/bin/msgfmt
checking for dcgettext... yes
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... /usr/bin/xgettext
checking for catalogs to be installed... az ca cs da de el en_CA en_GB es fi fr ga hr hu it ja ko lv ml nb nl no pa pl pt pt_BR ro ru sk sq sr sr@Latn sv tr uk vi zh_CN zh_TW
configure: creating ./config.status
config.status: creating Makefile
config.status: creating firestarter.spec
config.status: creating src/Makefile
config.status: creating src/xpm/Makefile
config.status: creating po/Makefile.in
config.status: creating pixmaps/Makefile
config.status: creating scripts/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing default-1 commands
config.status: executing default-2 commands
config.status: executing default-3 commands
make all-recursive
make[1]: Entering directory `/home/richard/source/firestarter-1.0.3'
Making all in po
make[2]: Entering directory `/home/richard/source/firestarter-1.0.3/po'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/richard/source/firestarter-1.0.3/po'
Making all in src
Making all in xpm
make[3]: Nothing to be done for `all'.
make[3]: Entering directory `/home/richard/source/firestarter-1.0.3/src'
nelz Moderator
Posted: Thu May 10, 2012 11:41 pm Post subject: |
Just included the whole output in a single set of code tags would have done it, as it is the most important part, the output, is not tagged. Anyway, you have solved your original problem by installing the dev packages, configure now completes without error and compilation starts.
You now have a completely different error, and one worthy of a bug report on the firestarter site. It appears you have an incompatible library version, but configure is not identifying this. The contact us page on the firestarter site has a link to their bug tracker. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
RichFox
Posted: Wed May 16, 2012 9:02 pm Post subject: |
Thanks nelz I will do that.
Rich _________________ Thanks in advance for any help.
Rich |
