Server/Client
RyanF109
PostPosted: Fri May 04, 2012 10:10 pm    Post subject: Server/Client Reply with quote
After becoming attached to and loving Linux followed by doing some work with Windows Server/Client support, i have been infuriated by Windows' usual slow speeds, problems, and general unreliability.
My question is; would it be realistic to deploy a network in a workplace using Linux servers and clients, instead of using Windows Server and Active Directory.
If so: What program(s) would provide similar results to Active Directory?
I generally feel that a Linux setup would be far more reliable and result in far less problems.
PostPosted: Fri May 04, 2012 11:28 pm    Post subject: Reply with quote
+1 on all accounts Wink
What you probably need is LDAP and Kerbekos:
http://en.wikipedia.org/wiki/Lightweight_Directory_Access_Protocol
http://en.wikipedia.org/wiki/Kerberos_(protocol) (link fails in forum, select the protocol from the page that shows up... Rolling Eyes )
Most distro's offer suitable packages from their repo's. Not having use for either I can't help you on these tools Cool
PostPosted: Sat May 05, 2012 12:30 am    Post subject: Reply with quote
You also need Samba, which is the linux equivalent of windows file and printer sharing.
And Winbind, which allows binding to a windows domain.
You might also be interested in BackupPC.
bobthebob1234
PostPosted: Sat May 05, 2012 12:50 am    Post subject: Reply with quote
There should totally be a tutorial or something on this subject. I have tried, managed to get a LDAP tree setup, but couldn't get Kerbekos, but I was young and didn't really know what I was doing.
Also +1 for BackupPC. Amazingly simple backup software
PostPosted: Sat May 05, 2012 12:53 pm    Post subject: Reply with quote
Try Kerberos with two 'r's Wink
However Kerberos is a protocol, not an app.
If you want a more complete and flexible solution for corporate authentication, authorisation and accounting (AAA) encompassing external network access across the Internet, alternatively check out the RADIUS protocol.
Any half-decent enterprise Linux distro should have suitable services for both these available.
Another thing you might want to think about is your email server: there are some pretty good Outlook substitutes around, though if your managers rely on horrible things like public folders or specialised apps that dig deep into the Outlook/desktop API, you will need to choose with care. I know at least one large outfit that has recently disabled public folders for this among other reasons.
Oh yeah, and for those specialised legacy apps that are tailored to IE, there is a neat Firefox extension for Windows called IETab. It basically fires up IE in the tab, so you can browse IE-specific services. IE can have trouble with the standards-compliant web interfaces Linux services, so Firefox plus IETab gives access to the whole lot, as well as giving more secure and flexible browsing of the public Internet.
So yes, Linux server / Windows client corporate environments are being increasingly do-able and increasingly seen. However be warned, it can be hard to root out (sic) all your Windows servers and you might spend quite a while with a mixed ecology.
Cheers,
Guy
The eternal noob
