get_iplayer file storage
Rich_b21
PostPosted: Thu May 03, 2012 11:47 am    Post subject: get_iplayer file storage Reply with quote
Can I tell get_iplayer to store an downloads in a particular file?
If so how is this done.
As I am new to this assume I know nothing.
Thanks.
Richard
Bruno
PostPosted: Thu May 03, 2012 12:34 pm    Post subject: Reply with quote
Hi Richard, I presume you mean directory, rather than file? From the command line, type:
Code:
get_iplayer --output <path to directory>
So, for example:
Code:
get_iplayer --output /home/<user>/Videos/
get_iplayer will then use this directory for downloads every time.
HTH
PostPosted: Thu May 03, 2012 12:50 pm    Post subject: Reply with quote
One way is to cd into the directory that you want the download to be in, then run the get-iplayer command Wink
PostPosted: Thu May 03, 2012 2:29 pm    Post subject: Reply with quote
Or you can set the environment variable IPLAYER_OUTDIR. That way you don't need to cd or add any options when you use get_iplayer.
Rich_b21
PostPosted: Thu May 03, 2012 2:35 pm    Post subject: Reply with quote
Thanks Bruno, yes, sorry I did mean directory.
Thank you all for your help, I will try to do what you have said.
Richard
