Rich_b21
Joined: Wed Mar 14, 2012 9:51 pm Posts: 32 Location: Near Ludlow
Posted: Thu May 03, 2012 11:40 am Post subject: Image of hard drive |
How do I make Image of hard drive please.
I am new to this so please assume that I know nothing.
Thanks
Richard |
Bruno LXF regular
Joined: Tue Sep 18, 2007 7:07 pm Posts: 139 Location: Cambridgeshire, UK
Posted: Thu May 03, 2012 12:43 pm Post subject: |
| Clonezilla is good for this. It's not terribly newbie friendly but not too hard either and the results are great. |
Rich_b21
Posted: Thu May 03, 2012 2:41 pm Post subject: |
Clonezilla is not on my distro (Ubuntu).
Please could you advise were it can be obtain from, or another programe |
reklan
Joined: Thu Mar 13, 2008 10:41 am Posts: 84 Location: Doncaster, Yorkshire
Posted: Thu May 03, 2012 3:09 pm Post subject: |
its downloadable from www.clonezilla.org.
get the latest ISO image burn it to a CD.
You can the image you machine to either another hard drive or any USB drive. (I use an external WD passport drive to save all images on) you can also use it to save /restore images from a network location with it. _________________ Don't Dream it....Be it.. |
Bruno LXF regular
Posted: Thu May 03, 2012 5:01 pm Post subject: |
| Sorry, I should have been more explicit. Clonezilla isn't so much a programme but a whole Linux distribution that runs from a Live CD. This means that you boot your computer from the CD, not from an operating system installed on your hard drive. From Clonezilla you can then image your hard drive. This method is preferable to using a programme installed on an OS booted from the internal HD. This is because if you are imaging an OS partition (for example), the host OS is not running, therefore it cannot change during the imaging process or deny you permission to read any of its files. |
Rich_b21
Posted: Thu May 03, 2012 10:08 pm Post subject: |
It is getting clearer........thanks
Richard |
Brian Hunter
Joined: Mon Feb 21, 2011 7:44 pm Posts: 74 Location: Glasgow, Scotland
Posted: Fri May 04, 2012 2:37 pm Post subject: |
Here is some documentation on cloning your hard drive. Takes you through all the steps.
Good luck and have fun! |
splash
Posted: Fri May 11, 2012 9:33 pm Post subject: |
dose that mean i can copy my drive and use the copy to another drive on another laptop?
I want to sync or copy my WEP/WAP files as i have about 20 and re typing them when i arrive with another laptop is a pain.
Also scrapbook in firefox is wonderful but the sync dosnt work nor dose transferring the files to another scrapbook work so an image of scrapbook and files would
Thanks for the clear advice really appreciate it |
dandnsmith LXF regular
Joined: Fri Apr 15, 2005 11:01 am Posts: 269 Location: Berks, UK
Posted: Sat May 12, 2012 8:08 am Post subject: |
| splash wrote: | | dose that mean i can copy my drive and use the copy to another drive on another laptop? |
Yes BUT it is only safe if the drive you're copying to is identical model and size. If you clone the entire drive, then restoring it to a different model and size drive may give you quite a mess to sort out (could even mess the drive for other purposes).
You can, however just clone the partition(s) with your OS (linux) and establish them on a new, partitioned, drive - you then need to set up the booting again by installing Grub on the new drive.
Good luck _________________ Derek |
splash
Posted: Sat May 12, 2012 1:10 pm Post subject: |
OH im not that advanced i though i would follow the instructions
The drive has C & D i suppose id have to copy D as that has XP?
where can i find the WAP WEP file id like to copy that at least |
nelz Moderator
Posted: Sat May 12, 2012 1:17 pm Post subject: |
If you onlywant to copy files, Clonezilla is not the correct tool as it wipes the destination drive. It sounds like you are best off keeping your key files on a USB stick. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
roseway LXF regular
Posted: Sat May 12, 2012 1:43 pm Post subject: |
| dandnsmith wrote: | | splash wrote: | | dose that mean i can copy my drive and use the copy to another drive on another laptop? |
Good luck |
That's not entirely true. I recently used Clonezilla to clone a failing 160GB disk to a new 500GB disk, including the MBR, and it produced a perfectly functioning copy, with 300-odd GB of unpartitioned space on the disk. _________________ Eric |
Posted: Sun May 13, 2012 11:00 am Post subject: |
Just so, roseway,
I too have restored a backup of a failing drive to another, not identical - but I have a long career of systems work which provides answers to any problems.
I merely caution an inexperienced user, as I have had to sort out some of these messes. _________________ Derek |
Steogede LXF regular
Posted: Mon May 14, 2012 12:30 am Post subject: |
| splash wrote: | OH im not that advanced i though i would follow the instructions
A. You really don't want to spend all the time involved copying a partition/disk just for a few WEP keys
B. You can't just copy a Windows system partition to another machine and expect that Windows install to work unless they are extremely similar hardware
C. You might be better off asking on a Windows forum about where Windows keeps it's WEP keys. Windows some times configures WEP using it's own utility and sometimes a manufacturer provided utility, whether any of these make the keys available to you is anyone's guess (Linux is much more straight forward about where it keeps it's config. - one of the reasons I prefer it)
D. If you can you should use WPA, it is more secure, plus the keys can be easier to remember and type. |
splash
Posted: Mon May 14, 2012 6:03 pm Post subject: |
I copied the WEP files yesterday to a USB drive the reason i wanted to clone them was the WEP didnt allow cut and paste last time i tried
Some of the WEP keys are to long.
My MAIN idea is to buy another netbook deleat win 7 basic and put on the drive XP and files from an old X40
If i use Nero on the new win 7 to copy a recovery disc.then format the drive,and install the OS and files from the old laptop??I hope |
