LXf 73 - mailtc
LXf 73 - mailtc
Postby dval » Wed Oct 26, 2005 12:22 pm
Hi guys,
As a noobie, I'm not fully sure how I do this so this may or may not sound stupid :)
mailtc - reviewed in LFX 73 needs GTK+ (2.4 or better) to install... I'm geting the error - "GTK 2.4 not found" during ./configure part of the installation
How do I know what version I have installed? and how do I load the upgrade through synaptic or apt-get?
I'm running Debian 3.1 semi-testing with GNOME 2.8 and KDE 3.4.3 loaded as per the almost default installation.
mailtc looks like a useful little app, no need to load a full size mail package etc, but the assumtion that "no fiddly dependacies only GTK+" misses the point slightly.
Thanks for any advice
Dave
David Valentine
Sony PCG-505FX
Debian 3.1 Sarge
Linux u.n 398915
dval
RE: LXf 73 - mailtc
Postby M-Saunders » Wed Oct 26, 2005 12:45 pm
Hi Dave,
Enter 'dpkg -l | grep gtk' at a shell prompt and it should reveal which version of Gtk+ you have installed. Chances are it's newer than 2.4, but you may not have the equivalent development package installed (used for compiling Gtk-based programs from source). This will be called 'gtk-dev' or 'libgtk-dev' or similar. Use Synaptic's search function to find the Gtk development package.
As for "fiddly dependencies", Gtk is extremely common and almost every distro provides it -- hence why it's not really problematic. "Fiddly" dependencies are those rarely-used and hard-to-find libraries that you typically have to compile from source, and they often have a string of dependencies of their own too...
If you still have trouble, it may be worth emailing the developer(s) and asking them to make an Autopackage. That'll allow you to just double-click it and go! See http://www.autopackage.org for more about the ultra-easy software installation system.
Good luck!
M
M-Saunders
RE: LXf 73 - mailtc
Postby dval » Thu Oct 27, 2005 10:25 am
Thanks M,
I will give that a try this evening, and let you know the result.
Dave
David Valentine
Sony PCG-505FX
Debian 3.1 Sarge
Linux u.n 398915
dval
RE: LXf 73 - mailtc
Postby dval » Fri Oct 28, 2005 7:55 am
Hi M,
Loaded the libs, the compile and install went off without a hitch, then I got a segment error when running the package I will send the result to the authors and see if they have a solution.
Thanks for your assist.
Dave
David Valentine
Sony PCG-505FX
Debian 3.1 Sarge
Linux u.n 398915
dval
