neilj LXF regular
Joined: Sun Oct 23, 2005 2:12 pm Posts: 106 Location: Kloof,KwaZulu Natal,South Africa
Posted: Fri Apr 20, 2012 2:11 pm Post subject: mailman |
I am trying to install mailman. I get the following error
Access denied per /etc/httpd/conf/webapps.d/mailman.conf
I have changed the permissions to read/write for everyone. I have changed Deny to Allow. But same error.
Any help will be appreciated. |
Dutch_Master LXF regular
Posted: Fri Apr 20, 2012 2:19 pm Post subject: |
You need to restart services (like mailman) in order to pick up any changes you've made.  |
neilj LXF regular
Posted: Fri Apr 20, 2012 2:40 pm Post subject: mailman |
| Thanks, That has worked |
neilj LXF regular
Posted: Fri Apr 20, 2012 2:47 pm Post subject: mailman error logs |
I have a new problem when trying to create a list. It says the error can be found in the mailman error logs. Where do I find them.
Is there any other mailing list manager. I have something called mailking on windows running on a virtual machine. Is there something like that available for Linux? |
Posted: Fri Apr 20, 2012 2:58 pm Post subject: |
Error logs can be found in /var/log so that should be your first stop. No idea on the mailing list manager, don't use them...  |
