Memory
Memory
Postby dhester » Wed Apr 18, 2012 4:22 pm
Does increasing the size of physical memory have the same impact on performance as it does in windows.
One of my computers has stopped working and I am thinking instead of trying to get it working again to put the components into one of the other computers running linux.
The machine I am thinking of upgrading has 2Gig of memory at present and I have another 2 gig that could go into the machine.
Would this improve the linux performance?
dhester
Postby ajgreeny » Wed Apr 18, 2012 9:46 pm
2GB of ram should be more than enough for a 32bit Linux OS, but if it is a 64bit OS it may show some worthwhile improvement in speed with the higher amount, of course.
ajgreeny
Postby wyliecoyoteuk » Wed Apr 18, 2012 9:54 pm
Depends what you are using it for really, Linux generally uses less resources, and swaps to disk less than Windows anyway.
Postby dhester » Wed Apr 18, 2012 10:54 pm
I decided to put the extra memory in the linux machine (32bit Mont 12) as I am going to replace the broken computer with a new motherboard which uses different memory anyway.
From my initial test the extra memory does not seam to make any difference, from my previous experience if this had been a windows machine it would have made a significant difference.
Does this mean Linux is memory efficient?
dhester
Postby lok1950 » Wed Apr 18, 2012 11:23 pm
Linux does tend to use all resources efficiently not just memory :wink: the main issue with Windows memory usage is that memory that has been released by a process is not always returned to available free memory so memory scrubbing apps running all the time have been the norm.Win7 is much better than previous versions but still not as efficient as the Linux kernel :D
Enjoy the Choice :)
lok1950
Postby Ben » Thu Apr 19, 2012 10:00 am
The command 'top' is your friend here. It will show you how the system resources are being used including how much memory is currently free, and how much load is on the processors (and which programs are using them). If you've got plenty of memory free under normal usage, then adding a bit more won't make any difference.
Ben
Ben
Postby bobthebob1234 » Thu Apr 19, 2012 10:58 am
htop is prettier... :)
bobthebob1234
Postby nelz » Thu Apr 19, 2012 12:40 pm
Maybe, but free is more informative than either as it differentiates between memory used by applications and that used by buffers and caches. It is the latter that improves performance on Linux, whereas filling up all your RAM with the former kills performance.
