Re-installation and making a list of installed software
Postby GeordieJedi » Sun Mar 25, 2012 1:48 pm
Hi all.
OK, I'm going to install 11.10 and I'd like to make a list of all the programmes and apps
that I've installed so-far. (To make it easier to re-install them afterwards).
So-far (I think I've made a correct list by doing the folowing in a terminal) =
dpkg --get-selections > installed_apps_01.txt
However I prefaced that command with sudo.
E.G.
sudo dpkg --get-selections > installed_apps_01.txt
and saved it to my home folder.
Now, is this enough? Was putting sudo in-front wise?
Will this enable me to run the next line of code to re-install all of the apps?
Thanks in advance for any help or advice.
GeordieJedi
Postby Dutch_Master » Sun Mar 25, 2012 3:15 pm
Yes, sudo was actually needed for that command so succeed. Next steps:
1) save the file on removable media (USB stick!), just in case (and backup your data too!)
2) on the new system, set the list with:
sudo apt-get --set-selections < installed_apps_01.txt
3) install these using dselect, this takes a while:
sudo apt-get install dselect
sudo dselect install
Assuming you've also updated to a new kernel, reboot, and you should be back in business.
Postby GeordieJedi » Sun Mar 25, 2012 5:05 pm
Brilliant !
Thanks for the prompt reply Dutch_Master.
Cheers.
GeordieJedi
