Mint 11 boot probs
DavidMcCrossan
PostPosted: Thu Feb 09, 2012 3:31 pm    Post subject: Mint 11 boot probs Reply with quote
From cold sys gives little sign of action. Screen lights up, and a little activity at the disc led, then screen shuts down and nothing, Even REISUB has no effect, and Ctrl-Alt-Del does not work. Big Red Button and try again. Same.
Before Button, opened DVD cover and inserted LXF DVD 154 to try Mint live DVD. Button then re-start, message "Verifying...and nothing else happened.
Start/stop a few times and finally system powered up as tho´ nothing had happened.
Here follows the relevant (to today) part of syslog 1
Code:
david-Aspire-E360 ntpdate[1463]: step time server 91.189.94.4 offset 70818.541751 sec
Feb  9 15:53:26 david-Aspire-E360 kernel: [   40.236391] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro,commit=0
Feb  9 15:53:26 david-Aspire-E360 kernel: [   40.240076] EXT4-fs (sda3): re-mounted. Opts: commit=0
Feb  9 15:53:26 david-Aspire-E360 init: plymouth-stop pre-start process (1927) terminated with status 1
Feb  9 15:58:08 david-Aspire-E360 kernel: [  322.417717] SysRq : Keyboard mode set to system default
Feb  9 15:58:09 david-Aspire-E360 kernel: [  323.073532] SysRq : Terminate All Tasks
Feb  9 15:58:09 david-Aspire-E360 kernel: Kernel logging (proc) stopped.
Feb  9 15:58:09 david-Aspire-E360 rsyslogd: [origin software="rsyslogd" swVersion="4.6.4" x-pid="767" x-info="http://www.rsyslog.com"] exiting on signal 15.
Feb  9 15:58:09 david-Aspire-E360 kernel: imklog 4.6.4, log source = /proc/kmsg started.
Feb  9 15:58:09 david-Aspire-E360 rsyslogd: [origin software="rsyslogd" swVersion="4.6.4" x-pid="1957" x-info="http://www.rsyslog.com"] (re)start
Feb  9 15:58:09 david-Aspire-E360 rsyslogd: rsyslogd's groupid changed to 103
Feb  9 15:58:09 david-Aspire-E360 rsyslogd: rsyslogd's userid changed to 101
Feb  9 15:58:09 david-Aspire-E360 rsyslogd-2039: Could no open output pipe '/dev/xconsole' [try http://www.rsyslog.com/e/2039 ]
Feb  9 15:58:09 david-Aspire-E360 cron[1936]: (CRON) INFO (pidfile fd = 3)
Feb  9 15:58:09 david-Aspire-E360 cron[1960]: (CRON) STARTUP (fork ok)
Feb  9 15:58:09 david-Aspire-E360 cron[1960]: (CRON) INFO (Skipping @reboot jobs -- not system startup)
Feb  9 15:58:09 david-Aspire-E360 acpid: starting up with proc fs
Feb  9 15:58:09 david-Aspire-E360 acpid: 32 rules loaded
Feb  9 15:58:09 david-Aspire-E360 acpid: waiting for events: event logging is off
Feb  9 15:58:09 david-Aspire-E360 init: dbus main process (1973) terminated with status 1
Feb  9 15:58:09 david-Aspire-E360 init: dbus main process ended, respawning
Feb  9 15:58:09 david-Aspire-E360 init: Unable to connect to the system bus: Failed to connect to socket /var/run/dbus/system_bus_socket: Connection refused
Feb  9 15:58:09 david-Aspire-E360 init: plymouth-upstart-bridge main process (1976) terminated with status 1
Feb  9 15:58:09 david-Aspire-E360 kernel: [  323.485202] <30>udev[1983]: starting version 167
Feb  9 15:58:10 david-Aspire-E360 kernel: imklog 4.6.4, log source = /proc/kmsg started.
Feb  9 15:58:10 david-Aspire-E360 rsyslogd: [origin software="rsyslogd" swVersion="4.6.4" x-pid="2009" x-info="http://www.rsyslog.com"] (re)start
Feb  9 15:58:10 david-Aspire-E360 rsyslogd: rsyslogd's groupid changed to 103
Feb  9 15:58:10 david-Aspire-E360 rsyslogd: rsyslogd's userid changed to 101
Feb  9 15:58:10 david-Aspire-E360 rsyslogd-2039: Could no open output pipe '/dev/xconsole' [try http://www.rsyslog.com/e/2039 ]
Feb  9 15:58:10 david-Aspire-E360 acpid: starting up with proc fs
Feb  9 15:58:10 david-Aspire-E360 acpid: 32 rules loaded
Feb  9 15:58:10 david-Aspire-E360 acpid: waiting for events: event logging is off
Feb  9 15:58:10 david-Aspire-E360 cron[1993]: (CRON) INFO (pidfile fd = 3)
Feb  9 15:58:10 david-Aspire-E360 cron[2015]: (CRON) STARTUP (fork ok)
Feb  9 15:58:10 david-Aspire-E360 cron[2015]: (CRON) INFO (Skipping @reboot jobs -- not system startup)
Feb  9 15:58:10 david-Aspire-E360 atd[2016]: Removing stale lockfile for pid 1959
Feb  9 15:58:10 david-Aspire-E360 udev-configure-printer: add /devices/pci0000:00/0000:00:10.0/0000:04:07.2/usb2/2-1/2-1.1/2-1.1:1.0
Feb  9 15:58:10 david-Aspire-E360 udev-configure-printer: parent devpath is /devices/pci0000:00/0000:00:10.0/0000:04:07.2/usb2/2-1/2-1.1
Feb  9 15:58:10 david-Aspire-E360 udev-configure-printer: add /devices/pci0000:00/0000:00:10.0/0000:04:07.2/usb2/2-1/2-1.1/2-1.1:1.0/usb/lp0
Feb  9 15:58:10 david-Aspire-E360 kernel: [  324.428668] <30>udev[2035]: starting version 167
Feb  9 15:58:11 david-Aspire-E360 kernel: [  324.681034] SysRq : Emergency Sync
Feb  9 15:58:11 david-Aspire-E360 kernel: [  324.694086] Emergency Sync complete
Feb  9 15:58:12 david-Aspire-E360 kernel: [  325.840708] SysRq : Emergency Remount R/O
Feb  9 16:01:07 david-Aspire-E360 kernel: imklog 4.6.4, log source = /proc/kmsg started.
Feb  9 16:01:07 david-Aspire-E360 rsyslogd: [origin software="rsyslogd" swVersion="4.6.4" x-pid="852" x-info="http://www.rsyslog.com"] (re)start
Feb  9 16:01:07 david-Aspire-E360 rsyslogd: rsyslogd's groupid changed to 103
Feb  9 16:01:07 david-Aspire-E360 rsyslogd: rsyslogd's userid changed to 101
Feb  9 16:01:07 david-Aspire-E360 rsyslogd-2039: Could no open output pipe '/dev/xconsole' [try http://www.rsyslog.com/e/2039 ]
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Initializing cgroup subsys cpuset
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Linux version 2.6.38-8-generic (buildd@vernadsky) (gcc version 4.5.2 (Ubuntu/Linaro 4.5.2-8ubuntu3) ) #42-Ubuntu SMP Mon Apr 11 03:31:50 UTC 2011 (Ubuntu 2.6.38-8.42-generic 2.6.38.2)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] BIOS-provided physical RAM map:
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]  BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]  BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]  BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]  BIOS-e820: 0000000000100000 - 000000003fef0000 (usable)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]  BIOS-e820: 000000003fef0000 - 000000003fef3000 (ACPI NVS)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]  BIOS-e820: 000000003fef3000 - 000000003ff00000 (ACPI data)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]  BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]  BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Notice: NX (Execute Disable) protection cannot be enabled in hardware: non-PAE kernel!
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] NX (Execute Disable) protection: approximated by x86 segment limits
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] DMI 2.2 present.
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] DMI: Acer Aspire E360/FC51GM  , BIOS R01-A4 10/28/2005
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] last_pfn = 0x3fef0 max_arch_pfn = 0x100000
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] MTRR default type: uncachable
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] MTRR fixed ranges enabled:
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   00000-9FFFF write-back
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   A0000-BFFFF uncachable
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   C0000-C7FFF write-protect
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   C8000-FFFFF uncachable
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] MTRR variable ranges enabled:
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   0 base 0000000000 mask FFC0000000 write-back
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   1 base 003FF00000 mask FFFFF00000 uncachable
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   2 disabled
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   3 disabled
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   4 disabled
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   5 disabled
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   6 disabled
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   7 disabled
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] found SMP MP-table at [c00f39d0] f39d0
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] initial memory mapped : 0 - 01c00000
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]  0000000000 - 0000400000 page 4k
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]  0000400000 - 0037400000 page 2M
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]  0037400000 - 00377fe000 page 4k
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] kernel direct mapping tables up to 377fe000 @ 1bfb000-1c00000
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] RAMDISK: 35c94000 - 36e42000
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: RSDP 000f7af0 00014 (v00 Nvidia)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: RSDT 3fef3040 00034 (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: FACP 3fef30c0 00074 (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: DSDT 3fef3180 06303 (v01 NVIDIA AWRDACPI 00001000 MSFT 0100000E)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: FACS 3fef0000 00040
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: SSDT 3fef95c0 000D6 (v01 PTLTD  POWERNOW 00000001  LTP 00000001)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: MCFG 3fef9700 0003C (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: APIC 3fef9500 00072 (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: Local APIC address 0xfee00000
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] 134MB HIGHMEM available.
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] 887MB LOWMEM available.
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   mapped low ram: 0 - 377fe000
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   low ram: 0 - 377fe000
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Zone PFN ranges:
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   DMA      0x00000010 -> 0x00001000
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   Normal   0x00001000 -> 0x000377fe
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   HighMem  0x000377fe -> 0x0003fef0
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Movable zone start PFN for each node
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] early_node_map[2] active PFN ranges
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]     0: 0x00000010 -> 0x0000009f
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]     0: 0x00000100 -> 0x0003fef0
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] On node 0 totalpages: 261759
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] free_area_init_node: node 0, pgdat c1784100, node_mem_map f6ffd200
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   DMA zone: 32 pages used for memmap
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   DMA zone: 0 pages reserved
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   DMA zone: 3951 pages, LIFO batch:0
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   Normal zone: 1744 pages used for memmap
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   Normal zone: 221486 pages, LIFO batch:31
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   HighMem zone: 270 pages used for memmap
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]   HighMem zone: 34276 pages, LIFO batch:7
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Using APIC driver default
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Nvidia board detected. Ignoring ACPI timer override.
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] If you got timer trouble try acpi_use_timer_override
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: PM-Timer IO Port: 0x1008
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] disabled)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: IRQ9 used by override.
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: IRQ14 used by override.
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] ACPI: IRQ15 used by override.
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Using ACPI (MADT) for SMP configuration information
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] SMP: Allowing 2 CPUs, 1 hotplug CPUs
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] nr_irqs_gsi: 40
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Allocating PCI resources starting at 3ff00000 (gap: 3ff00000:a0100000)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Booting paravirtualized kernel on bare hardware
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] PERCPU: Embedded 13 pages/cpu @f5800000 s28800 r0 d24448 u2097152
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] pcpu-alloc: s28800 r0 d24448 u2097152 alloc=1*4194304
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] pcpu-alloc: [0] 0 1
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 259713
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.38-8-generic root=UUID=f300cb15-8c50-4f5d-962c-d265219cb687 ro quiet splash vt.handoff=7
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Initializing CPU#0
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] allocated 5237120 bytes of page_cgroup
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Initializing HighMem for node 0 (000377fe:0003fef0)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Memory: 1005328k/1047488k available (5188k kernel code, 41708k reserved, 2540k data, 700k init, 138184k highmem)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] virtual kernel memory layout:
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]     fixmap  : 0xfff16000 - 0xfffff000   ( 932 kB)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]     pkmap   : 0xff800000 - 0xffc00000   (4096 kB)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]     vmalloc : 0xf7ffe000 - 0xff7fe000   ( 120 MB)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xf77fe000   ( 887 MB)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]       .init : 0xc178d000 - 0xc183c000   ( 700 kB)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]       .data : 0xc15112a1 - 0xc178c480   (2540 kB)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]       .text : 0xc1000000 - 0xc15112a1   (5188 kB)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] SLUB: Genslabs=15, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Hierarchical RCU implementation.
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]    RCU dyntick-idle grace-period acceleration is enabled.
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000]    RCU-based detection of stalled CPUs is disabled.
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] NR_IRQS:2304 nr_irqs:512 16
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] CPU 0 irqstacks, hard=f4c08000 soft=f4c0a000
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] spurious 8259A interrupt: IRQ7.
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] vt handoff: transparent VT on vt#7
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Console: colour dummy device 80x25
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] console [tty0] enabled
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Fast TSC calibration using PIT
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Detected 2009.246 MHz processor.
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.000000] Marking TSC unstable due to TSCs unsynchronized
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.008006] Calibrating delay loop (skipped), value calculated using timer frequency.. 4018.49 BogoMIPS (lpj=8036984)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.008013] pid_max: default: 32768 minimum: 301
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.008045] Security Framework initialized
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.008075] AppArmor: AppArmor initialized
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.008078] Yama: becoming mindful.
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.012010] Mount-cache hash table entries: 512
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.012174] Initializing cgroup subsys ns
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.012179] ns_cgroup deprecated: consider using the 'clone_children' flag without the ns_cgroup.
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.012184] Initializing cgroup subsys cpuacct
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.012190] Initializing cgroup subsys memory
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.012201] Initializing cgroup subsys devices
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.012205] Initializing cgroup subsys freezer
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.012208] Initializing cgroup subsys net_cls
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.012211] Initializing cgroup subsys blkio
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.012251] mce: CPU supports 5 MCE banks
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.012856] SMP alternatives: switching to UP code
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.020559] ACPI: Core revision 20110112
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.028037] ftrace: allocating 23640 entries in 47 pages
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.032081] Enabling APIC mode:  Flat.  Using 1 I/O APICs
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.032602] ..TIMER: vector=0x30 apic1=0 pin1=0 apic2=-1 pin2=-1
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.075043] CPU0: AMD Athlon(tm) 64 Processor 3200+ stepping 02
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] Performance Events: AMD PMU driver.
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] ... version:                0
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] ... bit width:              48
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] ... generic registers:      4
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] ... value mask:             0000ffffffffffff
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] ... max period:             00007fffffffffff
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] ... fixed-purpose events:   0
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] ... event mask:             000000000000000f
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] Brought up 1 CPUs
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] Total of 1 processors activated (4018.49 BogoMIPS).
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] devtmpfs: initialized
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] print_constraints: dummy:
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] Time: 15:00:47  Date: 02/09/12
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] NET: Registered protocol family 16
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] EISA bus registered
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] node 0 link 0: io port [8000, ffff]
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] TOM: 0000000040000000 aka 1024M
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] node 0 link 0: mmio [a0000, bffff]
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] node 0 link 0: mmio [40000000, dfffffff]
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] node 0 link 0: mmio [f0000000, fe02ffff]
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] node 0 link 0: mmio [e0000000, e04fffff]
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] bus: [00, 04] on node 0 link 0
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] bus: 00 index 0 [io  0x0000-0xffff]
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] bus: 00 index 1 [mem 0x000a0000-0x000bffff]
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] bus: 00 index 2 [mem 0x40000000-0xefffffff]
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] bus: 00 index 3 [mem 0xf0000000-0xffffffff]
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] ACPI: bus type pci registered
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
Feb  9 16:01:07 david-Aspire-E360 kernel: [    0.076004] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
Can any one tell me, please what has occurred, and what I should do now?
Best
David
DavidMcCrossan
PostPosted: Sun Feb 12, 2012 6:24 pm    Post subject: Mint 11 boot problems Reply with quote
Further to my last, I have made progress.
First an immediate backup of /home/david.
Then a full check of the HDD, which passed.
Next upgrade to Mint 12 - clean, as it includes erasing all files.
Restart did not happen. After several retries and some ¨cooling¨ off time, it did boot into Lisa. Then during downloads of software the speed dropped to 5kBs/sec on a 4Mbs/sec service. It was all over the place.
When it failed to reboot following upgrade it did not give a splash screen, and the fan was on at full blast. The screen lit up, and went out after a minute.
Lisa failed to discover one of my printers from a USB router, which had stopped working.
I suspect failing power supply and will investigate further.
As you can see, the system is working perfectly at this time.
Sorry to be a bore.
Best David
DavidMcCrossan
PostPosted: Tue Feb 14, 2012 4:24 pm    Post subject: Mint 11 boot problems [SOLVED] Reply with quote
I took the PC to my local dealer and he confirmed the PSU failure.
Also one of my two RAM chips was intermittent.
The USB card I had added to the PC was not working.
Delete PSU, USB card, and replace 1Mb RAM chips with 2GB and all is sweetness and light.
Best
David
