Need help with a segmentation fault
Postby stuarte9 » Thu Jan 12, 2012 2:37 pm
Hi all,
I'm teaching myself C++ and getting a segmentation fault with my latest small prog. The fault occurs within the following function, at the "std::cin" statement.
void getValues(int** theMatrix, int& theRows, int& theColumns)
   for (int row = 0; row < theRows; ++row)
      // prompt for values
      std::cout << std::endl << "Enter values for row " << (row + 1) << std::endl;
      // and then use a for loop to assign values from cin
      for (int column = 0; column < theColumns; ++column)
         std::cin >> theMatrix[row][column];
The intention of this function is to prompt for and read integer values into a 2D array.
Could someone please explain why I'm getting this fault as everything seems OK to me.
Thanks in advance,
Stuart
stuarte9
Solved!
Postby stuarte9 » Fri Jan 13, 2012 2:27 pm
Hi all,
Just a quick note to say I've now solved the problem outlined in my original posting. It boiled down to not putting an ampersand (&) at the beginning of variable "theMatrix" in the function header.
Stuart
stuarte9
