bobthebob1234 LXF regular
Joined: Thu Jan 03, 2008 9:38 pm Posts: 1356 Location: A hole in a field
Posted: Wed Jan 04, 2012 11:30 am Post subject: mysql joins |
I've not used joins before, but think they would be idea for what I want to do here.
I have tables events & dates.
events has event_id as its primary key
dates has event_id as a foreign key, and also date
an event can have many dates
I want to select all the events (only once) and order them by the (most recent) date
I have
| Code: |
SELECT * FROM events INNER JOIN dates ON events.event_id = dates.event_id GROUP BY `event_name` ORDER BY `date` DESC
which appears to work but isn't very pretty. Is there a better way?
Thanks _________________ For certain you have to be lost to find the places that can't be found. Elseways, everyone would know where it was |
greg.d
Posted: Wed Jan 04, 2012 5:00 pm Post subject: |
Is it the output you dont like or the query?
From what I can gather, because your 2 columns have the same name, you can use the USING clause instead of ON. Ie. USING(event_id) or something like that.
Other than that it looks ok to me, but I'm no expert. |
Posted: Sun Jan 08, 2012 10:55 pm Post subject: |
Well its more the query that is bothering me.
| Code: |
SELECT * FROM events, dates WHERE events.event_id = dates.event_id GROUP BY `event_name` ORDER BY `date` DESC
does the same thing, so I feel I may be missing the point of joins... _________________ For certain you have to be lost to find the places that can't be found. Elseways, everyone would know where it was |
CJLL LXF regular
Posted: Sat Jan 14, 2012 6:32 am Post subject: |
| bobthebob1234 wrote: | Well its more the query that is bothering me.
| Code: |
does the same thing, so I feel I may be missing the point of joins... |
Straight joins between multiple tables can easily be performed in the WHERE section.
However in your application you will eventually need to use left or right joins, where one table may be populated and the other isn't.
For example, supposing you want to list ALL events, with dates where appropriate.
Using your example, you would only list events that had dates but not the events which yet had to have dates created.
Therefore you need a different type of join, which will list all events and any dates attaching to those events.
The solution to this is a LEFT JOIN.
| Code: |
SELECT * FROM events LEFT JOIN dates ON events.event_id = dates.event_id GROUP BY `event_name` ORDER BY `event_name` DESC
To take this even further suppose you need to know which events do not have any dates, by checking to see if the date record is populated, you can easily find the answer.
| Code: |
SELECT * FROM events LEFT JOIN dates ON events.event_id = dates.event_id WHERE dates.event_id IS NULL GROUP BY `event_name` ORDER BY `event_name` DESC
*disclaimer* it's 5am and I've not tested the above queries _________________ --
The reward for self love is sticky hands |
maverickprowls
Posted: Sat Nov 10, 2012 1:14 pm Post subject: Re: mysql joins |
You say that you want to select your events only once, but this query will join each time there is a date for an event, so you'll get several rows returned for any event with more than one date.
For a single row for each event showing the most recent event you'd need something like this (note: not tested, and my experience is SQL Server so you might need to check the syntax for MySQL)
| Code: |
SELECT e.event_id, d.maxdate FROM events AS e
INNER JOIN
(SELECT event_id, MAX(date) AS maxdate FROM dates GROUP BY event_id) AS d ON d.event_id = e.event_id
ORDER BY d.maxdate DESC
This joins your events to only the most recent (max) date in your dates table.
Additionally, it's good practice to expand * to the fields you want to return, that way your queries don't (necessarily) break when you change your tables. |
