Fat_Tuesday
Posted: Tue Jan 03, 2012 7:27 pm Post subject: Laptop Random Shutdowns |
Hi all,
This is happening in ubuntu 11.10 and Vista. My lappy randomly shuts itself down and the only thing I can think of is that it's overheating (in Vista I was gaming using Steam, in ubuntu I was playing Warsow). I can get some canned air to clean the cobwebs and clag out but was wondering if there's a system log in ubuntu that I could check that would be of any use? |
Bruno LXF regular
Joined: Tue Sep 18, 2007 7:07 pm Posts: 139 Location: Cambridgeshire, UK
Posted: Wed Jan 04, 2012 6:32 pm Post subject: |
Hi There,
I think most or all of the logs on a linux system are located in /var/log/. Have a look at this page for more info. I think for start-up and shut-down info, you need /var/log/messages. Does the laptop just switch off instantly or does it run through the shut-down procedure first?
BTW, comments on the accuracy of my reply from any more-seasoned geeks would be welcome as I'm still learning. |
MartyBartfast LXF regular
Joined: Mon Aug 22, 2005 8:25 am Posts: 780 Location: Hants, UK
Posted: Wed Jan 04, 2012 8:52 pm Post subject: |
Not sure what it will put in the logs, but /var/log/messages is the place to look.
You might be able to check the CPU temp by opening up a console in Ubuntu and doing
FWIW If your fans are blocked the air can might not be a lot of use, it certainly wouldn't have been any use when the same thing happened to my daughters Dell as it was so stuffed with crud, the only way to clean it out was to open it up. _________________ I have been touched by his noodly appendage. |
nelz Moderator
Joined: Mon Apr 04, 2005 12:52 pm Posts: 7995 Location: Warrington, UK
Posted: Thu Jan 05, 2012 12:12 am Post subject: |
Doesn't Ubuntu use /var/log/syslog?
Anyway, the syslog may not have any temperature-related entries.I'd set up a cron task to send the output from sensors (part of lm_sensors) to a file every five minutes and look for any trends there. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
Fat_Tuesday
Posted: Sat Jan 07, 2012 11:48 am Post subject: |
| Thanks for the replies! Removing a ton of crap has cooled my lappy down loads and I'm now learning about cron jobs to keep an eye on whatever's left. Thanks again! |
